Results 1,491 to 1,500 of 1770
- Jan 2006
- 28
June 24th, 2010 09:23 PM #1491good day po, anyone knows here kung saan po may available na foglamps for crosswind xt 2010, masyado po kasing maliit ung sa sportivo eh, mas malaki po kasi ang diameter ng provision for foglamps para sa xt 2010....
June 24th, 2010 10:09 PM #1492
The foglamps of the Sportivo would be the same foglamps to be used should you opt to upgrade your XT with foglamps. You may be able to retrofit another type of foglamp but would likely need to fabricate it's bracket.
In addition, should you opt to use a non-OEM design foglamp, you would put at risk your XT's warranty unlike if you buy and use the Sportivo's foglamps, plug and play na yun since may wiring provision na for foglamp installation. All you need is the OEM foglamp and OEM switch.Last edited by Benzmizer; June 24th, 2010 at 10:12 PM.
June 25th, 2010 12:20 AM #1493
I have this loud tok sound that I sometimes encounter when backing up? I'm not sure where it's coming from, don't know where to start checking either, any ideas. ano kaya yung possible na tumutunog pag atras ko? leafspring? torsion bar? shocks? not really sure.
- May 2009
- 119
June 25th, 2010 04:57 PM #1494hello to fellow tsikoteers...my crosswind instrument panel backlight and led light on the AC switch is not lighting...meron po kayang fuse ito or bulb na needed replacement?meron na po kaya nag DIY nito pa post naman po dito..thanks
June 25th, 2010 06:03 PM #1495
- May 2010
- 48
June 25th, 2010 06:51 PM #1496good day mga sir.. magtanong lang po.. nung nasa nlex po kc ako kahapon meron po akong naramdamang vibration sa passenger side bandang side mirror.. ang takbo ko ay mga 120+ lang pag nag minor ako to 110-115 nawawala yung vibration.. ano po kaya ang i check ko sa oto ko.. kaka camber ko lang naman nung bumiyahe ako.. thnks po
- Nov 2008
- 125
June 27th, 2010 01:21 PM #1499anyone knows kung san at magkano yung hubcap ng sportivo? hehe. 423/piece kasi sa isuzu pasig, naginquire ako yesterday. TIA
Did you let the motor rest in between? These handheld pumps are not heavy duty.
Need recommendations on tire inflator.
