Results 4,241 to 4,250 of 5235
- Jan 2006
- 24
October 21st, 2008 07:09 PM #4241I'm also thinking its the release bearing or the pressure plate since they already change the clutch disc to a trooper model. Thanks guys for the inputs regarding this tranny noise were getting from our max's.
October 21st, 2008 11:13 PM #4242
My D-Max is a Dec '03 4x2 LS A/T. Ang problem ko naman sa kanya is that if I don't use the vehicle for at least 4 hours, on the next time that I shift from P to D, the vehicle doesn't move unless I step on the accelerator. However, once the vehicle starts moving, during the next time that I shift to D from P or N the vehicle will move on its own even if I don't step on the accelerator basta less than 4 hours yung duration nung pagkakahinto nung sasakyan. Yung pakiramdam pag sinusumpong siya parang naninikit yung brakes pero ilang beses ko nang pinacheck, free wheeling naman lahat. :confused:
- Jan 2006
- 191
October 23rd, 2008 12:06 PM #4243yun din ang problem ko..yung sa tranny..maingay at times pero pag apak ng clutch nawawala..release bearing nga kaya??another question..coolant pa ba gamit niyo sa mga max niyo??o distilled na lang..if coolant any coolant would suffice ba kahit di orig isuzu coolant???
October 23rd, 2008 12:57 PM #4244
October 23rd, 2008 05:35 PM #4245
vanleano, any coolant would suffice as long as its concentrated, you would replace it naman every 20,000kms
- Jan 2006
- 191
October 24th, 2008 09:57 AM #4246
October 24th, 2008 10:13 AM #4247
- Jan 2006
- 191
October 24th, 2008 12:34 PM #4248
- Oct 2008
- 1
October 24th, 2008 02:25 PM #4249
- Jan 2006
- 191
October 24th, 2008 04:25 PM #4250another question pa pala..ano magandang m/t oil para sa max natin??any brand would do ba basta tama viscosity???engine oil ang ginagamit sa m/t oil right???
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
