Results 1 to 7 of 7
    Aug 2003
    has anyone used them? matibay ba? di kasi tumatagal ung hp sa amin, 2-3 years nasisira talaga despite very light use. i'm thinking na kung siguradong masisira after some time, we might as well get a cheaper brand
    ok naman ... yung microtek ko na scanner around 1997 pa!!!
    maingay na nga (kasi hindi ko pa nagagrasahan) pero umuubra pa rin.
    pang printer port pa nga ang connection at generic na driver na ng microtek for winXP na ang driver nito.
    ayaw masira para mapalitan ko sana....
    Feb 2005
    Microtek? Matibay yan. Yung andito sa office eh 1998 pa ata ito (based dun sa fading warranty sticker). Umaandar pa naman.
    E yung Microtek na Plasma TV? 42" nya parang nasa 60K lang yata. Panay ang ads sa Inquirer.
    Feb 2005
    Not sure about their plasmas but IMO, Microtek is a known electronic gadget brand.
    Jul 2004
    Quote Originally Posted by wildthing View Post
    o
    Sir paano mo na nalalagyan ng grasa?
    Ang problema lang sa akin parang na stuckup yung scanhead niya.
    pwede pa ba ito?
    2 years na rin ang sa akin.
    Microtek also.
    Thanks dude.
    you need to open the scanner...depende sa model pero most of the bolt are found underneath and should be opened by a philips screwdriver.
    pagkakalas ng bolt, ibaligtad mo ulit at tsaka mo alisin yung taas (this would include the cover and the glass part)...maihiwalay mo na ito from the base (and the mechanical portion).
    Yung bakal na "runner" and dapat may grasa. You will need to use silicon grease (white ang color nito) and not the car grease (brown or red colored). Silicon grease is usually available sa electronic stores...eto yung grease na ginagamit sa mga IC or transistors that needs to be mounted on heatsink.
    HTH
Microtek scanners: ok ba?
