Results 1 to 10 of 15
- Feb 2008
- 898
August 26th, 2009 02:16 PM #1I'm planning to buy a new inkjet printer. However, masyadong mahal ang ink, some costs almost 1,000 pesos for black ink alone and only for around 250 prints....it appears that the costs of the printer is cheap but its use is expensive....Now, I saw some stalls in the mall selling CIS and it appears that while I may invest in the conversion kit, but in the end, I will reap its benefits with the cost of the ink....
my questions are:
1. How is the quality of the prints?
2. What printer brand and model will be cost effective?
3. How much per page will the cost turn out?
By the way, I will not use it for business but only for home use, projects of my kids, or maybe printing for my work done at home (but only when really necessary as I have a laser printer in the office()...
- Nov 2002
- 1,326
August 26th, 2009 02:27 PM #2kung konti ang print volume mo... maaaring makamura ka nga sa investment ng cis.. but baka di mo rin mabawi yung additional investment na iyon... there is a break even point somewhere....
sa cis systems naman, usually matatali ka sa epson... there are a lot of cis systems out there... ingat lang sa pagpili... pati na rin ng printer....
pinaka sulit na proposition is buy the entry level printer then convert to cis... worst case kahit masira agad yung printer, d ganun kasakit... but low end printers tend to be slow...
August 26th, 2009 02:46 PM #4
I think we are using Canon with an Ink-Rite CIS. Malapit lang kasi ang shop ng Ink-Rite sa UST (along Aurora Blvd siya).
Ok pa naman siya. Almost 2 years na, i think?
August 26th, 2009 02:55 PM #5
Our office is using Canon IP1880 with CIS.
Downside, color cartridge can suddenly fail requiring a replacement (new cartridge) to get working again. Aside from that, it works pretty well.
Color quality is a little off with the reds as compared to original (side by side).
August 26th, 2009 03:50 PM #6
Yes, one of our cartrige failed na nga pala. It was a Php650 repair at their head office/shop.
August 26th, 2009 04:48 PM #7
August 26th, 2009 09:16 PM #8
Consider a CIS if you have high printing volumes and you are printing daily. Otherwise just stick to the replacement inks.
Epson is a more CIS-friendly brand with the most availability of ink-compatible cartridges at CDR King.
August 26th, 2009 09:47 PM #9
Th problem with Epson printers is if the inkjet nozzle head is clogged, you need to have it replaced (or replace the entire printer given it's cheap).
February 17th, 2013 10:06 AM #10
Any recommended printers that are compatible with CISS or affordable na ink?
1. Epson
2. HP
3. Canon
hindi ko alam kung ano mas ok....
meron ako nakita yong epson na CISS na right out of the box.... hindi ko lang sure ang quality
HP - ink advantage na printer mukhang ok, ang pangit sa kanya ang colored niya ay tri-color, so pag ubos na Yellow sira na print....
Thanks in advance
