Results 1,301 to 1,310 of 1687
July 29th, 2020 01:16 PM #1301
July 29th, 2020 01:17 PM #1302
July 29th, 2020 01:41 PM #1303
I also chose Daikin. Compared the operation of top of the line 3.0 Hp inverter Panasonic and Daikin side by side. The Daikin is quieter for both the indoor and outdoor unit. It's so quiet, sometimes you can hardly hear it running. The only thing Panasonic has going for it is the more powerful fan motor. That's only appreciated at startup because it can cool the room a little bit faster. But feature-wise the Daikin has a lot more to offer.
- Apr 2012
- 3,469
July 29th, 2020 02:47 PM #1304
July 29th, 2020 03:02 PM #1305
July 29th, 2020 03:20 PM #1306
Mas mura pa Panasonic premium inverter kay Anson P31,500 katsa Fb marketplace, nagkatalo SA installation P7500 [emoji23]
Nagtanong Nako SA direct seller
Mukhang SA installation ako makakamura [emoji846]
[emoji666]SAMSUNG DIGITAL INVERTER (2020 MODEL)
[emoji843]1.0HP AR09TYHYE (P25,000)
[emoji843]1.5HP AR12TYHYE (P28,000)
[emoji843]2.0HP AR18TYHYE (P37,000)
[emoji843]2.5HP AR24TYHYE (P44,000)
[emoji666]SAMSUNG WIND FREE INVERTER (2020 MODEL)
[emoji843]1.0HP AR09TYGCG (P31,000)
[emoji843]1.5HP AR12TYGCG (P34,500)
[emoji843]2.0HP AR18TYGCG (P43,000)
[emoji843]2.5HP AR24TYGCG (P50,000)
[emoji666]SAMSUNG WINDFREE PREMIUM (2020 MODEL)
[emoji843]1.0HP AR10TYCAG (P35,500)
[emoji843]1.5HP AR13TYCAG (P39,000)
[emoji843]2.0HP AR18TYCAG (P47,000)
[emoji843]2.5HP AR24TYCAG (P54,500)
[emoji666]LG STANDARD DUAL INVERTER
[emoji843]1.0HP HS/N-09ISS (P29,500)
[emoji843]1.5HP HS/N-12ISS (P33,500)
[emoji843]2.0HP HS/N-18ISS (P42,500)
[emoji843]2.5HP HS/N-24ISS (P48,500)
[emoji666]LG PREMIUM (IONIZER)
[emoji843]1.0HP HS/N-09IPC (P34,000)
[emoji843]1.5HP HS/N-12IPC (P36,500)
[emoji843]2.0HP HS/N-18IPC (P46,000)
[emoji843]2.5HP HS/N-24IPC (P55,000)
[emoji666]LG DELUXE PREMIUM AIR PURIFIER
[emoji843]1.0HP HSN-09APD (P36,000)
[emoji843]1.5HP HSN-12APD (P41,000)
[emoji843]2.0HP HSN-18APD (P52,000)
[emoji843]2.5HP HSN-24APD (P61,000)
[emoji666]CARRIER ALPHA 2 INVERTER
[emoji843]1.0HP 53GCVE010-303P (P31,000)
[emoji843]1.5HP 53GCVE013-303P (P34,500)
FLOOR MOUNTED
[emoji843]4HP/3TR FP-53CFV036308 (P141,000)
[emoji666]CARRIER CRYSTAL 2 INVERTER
[emoji843]1.0HP 53GCVBS010-303P (P39,000)
[emoji843]1.5HP 53GCVBS013-303P (P43,000)
[emoji843]2.0HP 53GCVBS016-303P (P55,500)
[emoji843]2.5HP 53GCVBS024-303P (P63,500)
[emoji666]CARRIER X POWER GOLD III
[emoji843]1.0HP 53GCVB010-303P (P42,500)
[emoji843]1.5HP 53GCVB013-303P (P47,000)
[emoji843]2.0HP 53GCVB016-303P (P58,000)
[emoji843]2.5HP 53GCVB024-303P (P68,500)
[emoji666]DAIKIN KING SERIES INVERTER (2020 MODEL)
[emoji843]1.0HP FTKM25TVM (P45,000)
[emoji843]1.5HP FTKM35TVM (P49,000)
[emoji843]2.0HP FTKM50TVM (P61,000)
[emoji843]2.5HP FTKM60TVM (P70,000)
[emoji843]3.0HP FTKM71TVM (P92,500)
[emoji666]DAIKIN QUEEN SERIES INVERTER (2020 MODEL)
[emoji843]0.8HP FTKC20TVM (P32,000)
[emoji843]1.0HP FTKC25TVM (P35,500)
[emoji843]1.5HP FTKC38TVM (P39,500)
[emoji843]2.0HP FTKC50TVM (P49,500)
[emoji843]2.5HP FTKC60TVM (P56,000)
[emoji843]3.0HP FTKC71TVM (P76,000)
[emoji666]DAIKIN SMART SERIES INVERTER (2020 MODEL)
[emoji843]0.8HP FTKQ20TVM (P27,500)
[emoji843]1.0HP FTKQ25TVM (P33,000)
[emoji843]1.5HP FTKQ35TVM (P36,000)
[emoji843]2.0HP FTKQ50TVM (P45,000)
[emoji843]2.5HP FTKQ60TVM (P51,000)
[emoji666]DAIKIN ECO KING SERIES INVERTER (2020 MODEL)
[emoji843]1.0HP FTKQ25AXVL (P34,000)
[emoji843]1.5HP FTKQ35AXVL (P38,000)
[emoji843]2.0HP FTKQ50AXVL (P47,000)
[emoji843]2.5HP FTKQ60AXVL (P53,000)
[emoji666]KOLIN STANDARD INVERTER
[emoji843]1.0HP KSM-IW10-6H1M (P33,000)
[emoji843]1.5HP KSM-IW15-6H1M (P38,000)
[emoji843]2.0HP KSM-IW20-6H1M (P47,000)
[emoji843]2.5HP KSM-IW25-6H1M (P53,000)
[emoji666]KOLIN PRIMUS FULL DC INVERTER
[emoji843]1.0HP KSM-IW10AE-5G1M (P39,000)
[emoji843]1.5HP KSM-IW15AE-5G1M (P43,000)
[emoji843]2.0HP KSM-IW20AE-5G1M (P52,000)
[emoji843]2.5HP KSM-IW25AE-5G1M (P57,500)
[emoji843]2.9HP KSM-IW30AE-5G1M (P71,000)
[emoji666]KOLIN NON INVERTER
[emoji843]1.0HP KSG-100BIG (P26,000)
[emoji843]1.5HP KSG-150BIG (P30,500)
[emoji843]2.0HP KSG-200BIG (P38,000)
[emoji843]2.5HP KSG-250BIG (P45,500)
[emoji666]KOLIN NON INVERTER FLOOR MOUNTED BASIC
[emoji843]3TR KLG-SF40-3D1M (P70,000)
[emoji843]5TR KLG-SF70-3D1M (P99,000)
[emoji666]KOLIN INVERTER FLOOR MOUNTED
[emoji843]3TR KLG-IF40-2C1M (P99,000)
[emoji843]5TR KLG-IF70-2C1M (P148,000)
[emoji666]GREE INVERTER
[emoji843]1.0HP U-W09-3DR (P33,000)
[emoji843]1.5HP U-W12-3DR (P35,500)
[emoji843]2.0HP U-W18-3DR (P45,000)
[emoji843]2.5HP U-W24-3DR (P54,000)
[emoji843]4.0HP U-W36-3DR (P83,000)
[emoji666]CONDURA HI-WALL MOUNTED INVERTER
[emoji843]1.0HP FP-53KXV009313 (P38,000)
[emoji843]1.5HP FP-53KXV012313 (P43,000)
[emoji843]2.0HP FP-53KXV018313 (P53,000)
[emoji843]2.5HP FP-53KXV022313 (P61,000)
[emoji666]KOPPEL SUPER INVERTER III
[emoji843]1.0HP KV09WM-ARF21C2 (P35,000)
[emoji843]1.5HP KV12WM-ARF21C2 (P39,000)
[emoji843]2.0HP KV18WM-ARF21C2 (P49,000)
[emoji843]2.5HP KV24WM-ARF21C2 (P54,000)
[emoji843]3.0HP KV27WM-ARF21C2 (P74,000)
[emoji666]KOPPEL NON INVERTER
[emoji843]1.0HP KSW-09R5DA (P27,000)
[emoji843]1.5HP KSW-12R5DA (P30,000)
[emoji843]2.0HP KSW-18R5DA (P39,000)
[emoji843]2.5HP KSW-24R5DA (P46,000)
[emoji666]KOPPEL NON INVERTER FLOOR MOUNTED
[emoji843]3TR KFM-36EOA (P71,000)-commercial
[emoji843]3TR KFM-36EOC (P76,000)-residential
[emoji843]5TR KFM-60EOA (P100,000)-horizontal
[emoji843]5TR KFM-60EOA (P99,000)-vertical
[emoji666]KOPPEL INVERTER FLOOR MOUNTED
[emoji843]3TR KV36FM-ARF21C (P100,000)
[emoji843]5TR KV60FM-ARF21C (P157,000)
[emoji666]PANASONIC STANDARD INVERTER
[emoji843]1.0HP CS/CU - PU09VKQ (P33,000)
[emoji843]1.5HP CS/CU - PU12VKQ (P37,000)
[emoji843]2.0HP CS/CU - PU18VKQ (P49,000)
[emoji843]2.5HP CS/CU - PU24VKQ (P58,000)
[emoji666]PANASONIC DELUXE
[emoji843]1.0HP CS/CU - XU09VKQ (P38,000)
[emoji843]1.5HP CS/CU - XU12VKQ (P42,000)
[emoji843]2.0HP CS/CU - XU18VKQ (P53,000)
[emoji843]2.5HP CS/CU - XU24VKQ (P62,000)
[emoji843]3.0HP CS/CU - XU30VKQ (P77,000)
[emoji666]PANASONIC SKY SERIES
[emoji843]1.0HP CS/CU - VU09UKQ (P49,000)
[emoji843]1.5HP CS/CU - VU12UKQ (P55,000)
[emoji843]2.0HP CS/CU - VU18UKQ (P67,000)
[emoji666]TCL TITAN GOLD FULL DC INVERTER
[emoji843]1.0HP TAC-09CSA/KEI (P29,000)
[emoji843]1.5HP TAC-12CSA/KEI (P33,000)
[emoji843]2.0HP TAC-18CSA/KEI (P42,000)
[emoji843]2.5HP TAC-25CSA/KEI (P48,000)
[emoji666]HAEIR FULL DC INVERTER
[emoji843]1.0HP HSU-09NSV13 (P29,000)
[emoji843]1.5HP HSU-12NSV13 (P33,000)
[emoji843]2.0HP HSU-18NSV13 (P42,000)
[emoji843]2.5HP HSU-24NSV13 (P48,000)
[emoji734]MIDEA HI-WALL MOUNTED INVERTER
[emoji666]PREMIUM ULTIMATE COMFORT
[emoji843]1.0HP FP-53AST010KEIV-T4 (P31,500)
[emoji843]1.5HP FP-53AST015KEIV-T4 (P34,000)
[emoji843]2.0HP FP-53AST020KEIV-T4 (P43,000)
[emoji843]2.5HP FP-53AST025KEIV-T4 (P51,000)
[emoji666]STANDARD AURORA WHITE
[emoji843]1.0HP FP-53AST010KEIV-W5 (P27,500)
[emoji843]1.5HP FP-53AST015KEIV-W5 (P30
- Apr 2012
- 3,469
July 29th, 2020 10:01 PM #1308
July 29th, 2020 10:24 PM #1309
We got our Daikin D Smart Queen 3hp for 72k with free installation last month, QC accredited dealer Fairview area. May additional fee lang dun sa pagbutas ng wall at additional cable length para sa provide yung power supply.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
