Results 1,111 to 1,120 of 1687
December 30th, 2018 06:02 PM #1111
Collateral damage from maintenance, leaks, repeated repairs, replacement (the chipping, masonry work, paintwork, floor & wall rehab, etc) can consume patience & tolerance. They downgrade to the real 'upgrade' of simplicity & practicality...the window.[emoji4]
December 30th, 2018 09:39 PM #1112
Basta ako personal experience ko mas okay split type. We used to be all window-type before. Ngayon isa nalang yung window type namin, nasira pa. So now I have to buy 3 aircons instead of just 2. [emoji23]
Super mas tahimik when I switched from window to split. Also the aesthetics of the room, sobrang mas malinis tingnan.
Never naging bothersome for me maintenance. Tagal na rin naming naka-split type sa bahay and never ko naexperience yung mga hassle na sinasabi dito. Kaya nga kung first-hand experience ang best basis, ok na ok ako sa split type.
- Nov 2017
- 1,748
December 30th, 2018 09:55 PM #1113Mukhang me bad experience si travajante sa split type.. Well look for good installer and invest on good quality foam insulation sa piping.. Use 1" size pipe as drain pipe. Importante kung maiiwasan yung mahabang linya.. Tama ka mas malapit yung blower sa condenser mas maganda [emoji16]
December 30th, 2018 09:59 PM #1114
They both have pros and cons. For me, split type is for aesthetics. It's just weird that before my split type would leak every six months while I never had a problem with window type even if I don't have it cleaned for years. What I don't like about window type is the hole in the wall (which is minor).
December 30th, 2018 10:06 PM #1115
December 30th, 2018 10:22 PM #1116
December 30th, 2018 10:23 PM #1117
December 30th, 2018 10:29 PM #1118
December 30th, 2018 10:32 PM #1119
December 30th, 2018 10:57 PM #1120
Nah, I just shared the pros, cons & measures needed. We even specify a minimum of 1.25" PPR drain, not blue. Splits are ideally installed along perimeter walls, where possible, to avoid lines running thru ceilings. If unavoidable, the insulated lines must be laid on gutter trays or thru pipes...I can go on & on.
Though I find joy in those of others, leak therapy isn't fun. Leaks can leave indelible scars, literally & figuratively.[emoji17]
Please don't get me wrong...I'm not anti-anything here. Just sharing to help prevent splitphobia.
