Results 1 to 15 of 15
    I'm planning to buy a new inkjet printer. However, masyadong mahal ang ink, some costs almost 1,000 pesos for black ink alone and only for around 250 prints....it appears that the costs of the printer is cheap but its use is expensive....Now, I saw some stalls in the mall selling CIS and it appears that while I may invest in the conversion kit, but in the end, I will reap its benefits with the cost of the ink....
    my questions are:
    1. How is the quality of the prints?
    2. What printer brand and model will be cost effective?
    3. How much per page will the cost turn out?
    By the way, I will not use it for business but only for home use, projects of my kids, or maybe printing for my work done at home (but only when really necessary as I have a laser printer in the office()...
    kung konti ang print volume mo... maaaring makamura ka nga sa investment ng cis.. but baka di mo rin mabawi yung additional investment na iyon... there is a break even point somewhere....
    sa cis systems naman, usually matatali ka sa epson... there are a lot of cis systems out there... ingat lang sa pagpili... pati na rin ng printer....
    pinaka sulit na proposition is buy the entry level printer then convert to cis... worst case kahit masira agad yung printer, d ganun kasakit... but low end printers tend to be slow...
    Sep 2005
    kung cannon and epson.. you can buy cheap inks at CD-R KING.
    I think we are using Canon with an Ink-Rite CIS. Malapit lang kasi ang shop ng Ink-Rite sa UST (along Aurora Blvd siya).
    Ok pa naman siya. Almost 2 years na, i think?
    Our office is using Canon IP1880 with CIS.
    Downside, color cartridge can suddenly fail requiring a replacement (new cartridge) to get working again. Aside from that, it works pretty well.
    Color quality is a little off with the reds as compared to original (side by side).
    Yes, one of our cartrige failed na nga pala. It was a Php650 repair at their head office/shop.
    With our Canon, just buy a new cartridge and have the CIS shop install the new cartridge.
    Consider a CIS if you have high printing volumes and you are printing daily. Otherwise just stick to the replacement inks.
    Epson is a more CIS-friendly brand with the most availability of ink-compatible cartridges at CDR King.
    Th problem with Epson printers is if the inkjet nozzle head is clogged, you need to have it replaced (or replace the entire printer given it's cheap).
    Jun 2008
    Any recommended printers that are compatible with CISS or affordable na ink?
    1. Epson
    2. HP
    3. Canon
    hindi ko alam kung ano mas ok....
    meron ako nakita yong epson na CISS na right out of the box.... hindi ko lang sure ang quality
    HP - ink advantage na printer mukhang ok, ang pangit sa kanya ang colored niya ay tri-color, so pag ubos na Yellow sira na print....
    Thanks in advance
    May 2011
    Quote Originally Posted by mbk347 View Post
    1. Epson
    2. HP
    3. Canon
    Thanks in advance
    Canon printers with CISS are good. Meron kami 4 Canon ip2772 printers in our office, and one for home use, all of which are converted into CIS and so far no problems. AFAIK ang hirap daw iconvert to CISS ang mga HP printers.
    Quote Originally Posted by attyallanlatras View Post
    my questions are:
    You can save a bit of money by buying the EPSON L110 printer with built-in CIS system. It comes with a bottle of each color and retails under P6,000. Price sounds a lot but considering the alternative is buying a printer and having a 3rd party install their CIS which invalidates the warranty, the price is fine.
    And if your EPSON L110 develops a problem during warranty period, you can still claim the warranty for repair. I have one at my office which developed a problem during warranty period and I had it repaired for free.
    Meron ako nito sa canon printer ko. Almost 3 years na maganda pa rin print. Yun nga lang medyo messy pag nagrerefill ka, minsan nabubuhos. Sobrang tipid kasi yung 75 petot na bote can print up to 3k pages or more. (6 rims ng coupon bond). Sulit na sulit ko to specially nung thesis days.
    1. Epson
    2. HP
    3. Canon
    Thanks in advance
    How often do you print and in what quantities? For home use, I'd suggest to just stick with an HP K110a Ink Advantage. Nevermind that it uses a tri-color cartridge, Epson's single color cartridge actually costs more per print than the HP cartridge.
    From my experience with CIS (Canon iP1880), it gave subpar prints, the colored cartridge broke 1 week after installation, I had more frequent print jams and ink blotches, and so on.
    A lot of Epson L-series CIS printers are also complaining about the reliability of their units, especially with regard to their waste tank, since the printer has a sensor that only allows a limited number of refills.
    Jun 2008
    not so much boss... i have a brother MFC-3360C that i just got repaired * compuserve, but busted again.... paper jam error...
    but no paper inside.... i do light printing.... projects for the kids and some reports.... some scanning of pictures....
    boss GH recommended a repair shop in mandaluyong... if its too expensive i might be tempted to buy a new one....
    seperate functions... parang mahirap ang multi-function.... now i cant even my fax & scanner.... hehe...
    i might be tempted to look * HP printers again.... we used to have a HP-710, lasted for years.... the ink was a pain though....
    around 800 per catridge, i think.... hehe....
Printer and CIS (Continuous Ink System)
