Results 1 to 5 of 5
September 2nd, 2007 05:35 PM #1
http://marco-za.blogspot.com/2007/08...simulator.html
Google Earth Flight Simulator
Some time last week, Google expanded Google Earth with Google Sky. As fascinating as Google Sky is, that's not the focus of this post. Along with the latest update comes a hidden feature of which I cannot seem to find any other information about. It's not in the release notes and a search on Google produces no results. Seems Google have done one of their unpublicised updates they're becoming well-known for.
What I'm talking about is a flight simulator embedded within GE. Sounds awesome, doesn't it? If the thought amazes you as much as it did me, then might have run off and tried it for yourself. But there's a problem. Remember what I said above - it's a hidden feature!
First of all you'll have to install the latest version of GE. Once you've started it all up, explored Google Sky a bit, then all you have to do is hit Ctrl+Alt+A (if you're running OS X it's Command+Option+A; some people have reported that Ctrl+A or Ctrl+Windows+A work when the standard Ctrl+Alt+A does not). If all goes as planned the following dialog should pop up:
As you can see from the screenshot there are only two aircraft to choose from at this stage. The F16 I find is much more enjoyable for a quick stint as it goes much faster than the SR22. Try both though as they're quite different flights. Then you get to pick a start position. The default option of Kathmandu runway gives you in the following scene:
September 4th, 2007 01:34 AM #5
i tried it out....astig...herherherh
hirap nga lang controls with mouse!
Xiaomi E-Car
