Results 1 to 10 of 99
- Aug 2003
- 9,720
May 13th, 2014 10:41 AM #1Water level at Angat Dam dips below critical level
Just trying to grasp what's been said in recent articles:
1. Just how many % of the power to MM is dependent on Angat?
2. At what levels should we worry about brownouts?
3. i read another article that said "at 160m, water faucets could run dry" -- was this meant literally?
4. Another article also mentioned the possibility of rationing water in MM to 42cubic meters per household; how does this work actually? i don't think they have the means to control the consumption per household, so does it mean that, say for barangay X, we will let Y cubic meters flow out, then shut it off? E di unahan na yan?
- Sep 2013
- 630
May 13th, 2014 12:39 PM #2Sobra sobra ulan nakukuha ng pilipinas every year pero pag dating ng summer na 3months lang eh hirap sa tubig ang metro manila.
May 13th, 2014 02:06 PM #3
May 13th, 2014 02:37 PM #5
May 13th, 2014 06:27 PM #6
Exactly! Year after year, the same cycle of issue is raised.
Pag summer , water level is in critical, supply will be rationing again. Blackout in Mindanao , MM at risk of brownouts.
Pag tag ulana na, dams are to over spill, towns will go under water once flood gate is opened. Esteros & spill ways are
clogged.
School opening, hundreds of school to raise tuition fees.
Yet, what has goverment done to improve the repetitive problems, WALA! Cause the money ends in the pocket.
May 13th, 2014 07:52 PM #7
What's worrying about this year is the forcasted El nino starting this June that may last til early next year...
Posted via Tsikot Mobile AppLast edited by Monseratto; May 13th, 2014 at 07:55 PM.
- Aug 2003
- 9,720
May 15th, 2014 10:00 AM #10At what levels do our dams have to drop down to before we have to worry about rotating blackouts?
i just read an article about a proposal to build two more dams to supply water to MM; that's a good idea, 10 years ago Sigurado pag tag ulan na e makakalimutan na to.
well, it is common knowledge that our daily ncr driving condition falls under "severe" driving...
Mitsubishi Xforce
