Results 1 to 5 of 5
    Please help any information regarding bit ******* file,i dont know how to open a file using ********,and bit ******* file i installed already software like *******,and bittorent but doesnt work pls help step by step,?
    Jan 2003
    sir,
    punta kayo sa isang ******* site. search po kayo ng file na gusto nyong i-dl. click nyo po yung gusto nyong idownload tas click download ******* na link. tas may lalabas na dialog box na magtatanong kung ano gusto mong gawin. gawin mong open with *******, for example. ayun idodownload na nya yung file mo...
    bro actually n dl ko n yung file tpos i save it to my desktop at pag katapos di ko na alam kung pano paganahin i used ******* and ******** softwre pero di pa rin gumagana at bkit ang tgal mag dl walang katapusan eto yung gamit ko n softwre..
    you're using bit comet pala.. have you tried to drag and drop the file? nevertheless, opening the file should also produce the same effect.
    you said you also tried to open it using ******** but to no avail. so anong ******* site ka kumukuha ng *******s?
    lately, hindi ako nag-DL because of the slow connection.. :sad:
    Try using u*******. Its a light and easy to use client. After installing it just press ctrl+G to start the setup wizard and select your internet connection speed and you're set.
    http://www.u*******.com
    Here is a link to the beginners guide when using u******* so you can add ******* files to the client:
    http://www.u*******.com/beginners-guide.php
how to open Bit ******* file..
