Results 1 to 11 of 11
    nabaha yung mga power tools ko nung nag flashflood sa antipolo.
    gumagana pa naman, kaso ang pansin ko, at low power settings ayaw na umikot.
    may alam po ba kayong service centers ng Black and Decker and Makita tools?
    thanks!!!!
    baka grounded kasi basa pa. try mo muna i-open (wala naman na warranty yan siguro?) tapos clean mo ng crc contact cleaner then lubricate mo bearings/bushings ng wd40. yun din gagawin nila sa service shop. mahilig ka naman siguro magbutingting (or else wala ka sana nyang mga power tools) so butingtingin na yan!
    Mar 2005
    wd40 is not a lubricant...
    WD is water dispersant. It is not a lubricant, but it can work for your intended application.
    Jan 2003
    Bring it to Anonas Construction , located at Anonas cor. Kamias QC.
    Tel 929 29 55
    Service Center sila ng power tools
    thanks guys! sige sir yebo, bubutingtingin ko muna. haha
    progen, will try that shop. dunko actually nabili unang set ng tools ko.
    thanks!
    May 2005
    Quote Originally Posted by Psylocke View Post
    correct si sir Pyslocke,kasama ko nag momotor ,nag spray sa chain ng MC niya .after a week .nasira ang kadena buti hindi naaksidente
    Mar 2005
    if you spray wd40 into bearing it will remove the grease
    no grease in bearings, bad...
    WD40 is actually a useless liquid, I don't even buy the stuff anymore...
    Apr 2006
    sir,
    anong klaseng powertools ng B&D ang nasa iyo corded ba siya or cordless?
    Patuyuin mo lang ng maayos at konting buga buga ng hangin baka sakaling
    maayos na din yan...
    WD40 is a penetrating oil/ degreaser and not lubricant, kaya kung gagamitin mo pang linis okay lang. But for lubrication never mong gamitin.
    Cheers!!!
    Kapag wala akong degreaser dito sa bahay ginagamit ko iyang WD40. Hehehe. Sinasabon ko na lang after.
    May 2005
    Quote Originally Posted by D_rock_777 View Post
    sir,
    maayos na din yan
    Cheers!!!
    try nyo patuyuin or ibilad mag hapon ..at pag satingin nyo dry na ang loob niya ,subukan nyo muna press sandali ang ON button ,pag sa wala naman kayo naramdaman hindi maganda ang andar ..deretso nyo paandarin
    para malaman nyo kung bumalik na sa normal running condition
HELP from DIYers re power tools
