nabaha yung mga power tools ko nung nag flashflood sa antipolo.
gumagana pa naman, kaso ang pansin ko, at low power settings ayaw na umikot.
may alam po ba kayong service centers ng Black and Decker and Makita tools?
thanks!!!!
thanks!!!!
baka grounded kasi basa pa. try mo muna i-open (wala naman na warranty yan siguro?) tapos clean mo ng crc contact cleaner then lubricate mo bearings/bushings ng wd40. yun din gagawin nila sa service shop. mahilig ka naman siguro magbutingting (or else wala ka sana nyang mga power tools) so butingtingin na yan!
WD is water dispersant. It is not a lubricant, but it can work for your intended application.![]()
Bring it to Anonas Construction , located at Anonas cor. Kamias QC.
Tel 929 29 55
Service Center sila ng power tools
thanks guys! sige sir yebo, bubutingtingin ko muna. haha
progen, will try that shop. dunko actually nabili unang set ng tools ko.
thanks!
if you spray wd40 into bearing it will remove the grease
no grease in bearings, bad...
WD40 is actually a useless liquid, I don't even buy the stuff anymore...
sir,
anong klaseng powertools ng B&D ang nasa iyo corded ba siya or cordless?
Patuyuin mo lang ng maayos at konting buga buga ng hangin baka sakaling
maayos na din yan...
WD40 is a penetrating oil/ degreaser and not lubricant, kaya kung gagamitin mo pang linis okay lang. But for lubrication never mong gamitin.
Cheers!!!
