Results 1 to 11 of 11
    Oct 2008
    Good morning!
    meron ako voltage regulator para sa computer. gusto ko sana gamitin para sa old school namin na tv 20 inche na Sony Wega?
    yong tv mga 100+ watts ang alam ko. yong voltage regulator naman naka lagay 5a tapos me nakalagay for computer use only. ang alam ko mga desktop e 500watts(not sure kasi di ba normal power supply nila e 500 watts?),
    ok lang ba voltage regulator na yon para sa tv?
    thanks
    Quote Originally Posted by african888 View Post
    Good morning!
    thanks
    if the AVR numbers are honest and not over-rated (continuous output and not PMPO), puede po.
    but my question is, "what for?"
    i have an ancient 20 year old wega at home, still running, without having had the benefit of any form of AVR.
    they are not like computers, where information is lost when the power winks even a bit.
    good luck.
    Apr 2014
    Afaik. Voltage regulator is for trimming out voltage spikes.
    Avr's are better especially servo in terms of protection.
    Kung ang area nyo is di consistent ang voltage sa line, mas ok nga lagyan ng avr or at the very least voltage regulator.
    TS says his voltage regulator is for the computer. it's an avr.
    but i have a question.
    which will adequately protect our devices from voltage fluctuations: the servo-type avr, or the smaller, electronic avr associated with freebies when we buy a computer system?
    Jul 2013
    Ganyan ginagamit namin sa bahay. Yung cheapipay na computer AVRs kasi nasira na yung mamahaling AVR namin hehehe
    Kailangan sa amin kasi patay-sindi kung magbrownout sa amin.
    Apr 2014
    Was thinking it was a power strip. Need to have coffee muna.
    Mas better ang servo since compensated nya din yung dip in voltage. However, the cost might be prohibitive lalo na kung basic use lang.
    Had a servo avr for 15 years until it was submerged sa baha. Sayang din.
    Oct 2008
    yes po, cheap avr lang po sya. parang 500 po bili ko non sa V Mall. and usually ito nga yong naka bundle na free pag bili ka ng desktop.
    so ok lang po na gamitin ko sa TV namin? kaysa naka tambak lang kasi wala na rin gumagamit ng desktop namin
    if your avr is like mine vis a vis capacity, kaya yan.
    ours powers the wega + cable tv black box + multimedia player.
    i use it because the wall socket is "far away". pang-extension cord lang siya dito.
    Aug 2012
    IIRC, mas delikado pa daw yang cheap AVR kasi dirty voltage ang output. May mga cases na sumasabog pa yan dahil cheap parts inside. Kaya nga free lang yan sa computer.
    If gagamit ka ng AVR, yung servo type dapat. Ganito type lahat AVR namin sa bahay.
    Sent from my ASUS_X00DDA using Tapatalk
    Jul 2013
    Quote Originally Posted by red_one View Post
    There maybe some truth to that. 2 audio component namin ang nasira dahil jan hehehe.
    Jan 2009
    We have had two Stac servo-type AVRs that bit the dust. Both of them had servo circuit failure due to input voltage spikes. Servo-type AVRs may be good on output accuracy, but it is typically slow to respond to fast and significant voltage increases and brownouts.
    For that matter, I've moved to using UPS's with built-in relay-type voltage regulation on all my sensitive equipment (home server and network equipment, entertainment center, bedroom TV, and of course, our family PC). Relays may not be as accurate with output (typical accuracy of +/- 10V on the output), but it responds instantly to transient rise and drops of the input voltage. And if it goes beyond what the internal AVR can correct, the battery kicks in, totally protecting the equipment.
    Equally important is to make sure that your equipment are properly earthed/grounded. The surge suppression circuit inside most equipment, including power strips, UPS, or AVRs with built-in surge suppression, relies on the ground pin to dissipate power surges, typically as a result of nearby lightning strikes or when a nearby heavy inductive load starts up, etc.
voltage regulator para sa 20 inch Sony wega tv
