Results 1 to 15 of 15
    Is there such a textcard that you buy and when you text in the PIN#, you'll be allowed to use unlimited text on the 3 telcos for a period of time?
    If there is, let me know where to buy it.
    Sep 2006
    Unheard of.
    Jun 2005
    I wish it would become reality.
    Apr 2006
    meron po nyan kaso ang dating po hindi yng no mo ang lalabas itetext mo pa sya sa ibang no tas sila ang mag foforward bagong pakulo to ng mga tao yng mga pyramid,legacy etc.... basta totoo yan kaso ang pangit ng service alam ko. 100 petot yata sya for 1month di ko lng sure...
    Quote Originally Posted by jasprit View Post
    Yey! Thanks sa info. :P
    100 a month is very cheap. Like Sun's first stint of 24/7, this should have a catch.
    i also heard of that card. ang daming nagpopost sa mga forums, willing to franchise ala e-load. i dont know if it took off. probably not...
    meron po. i just forgot the name. 100 sya per card, dunno lang for how many days.
    TSS! Thanks to postpaid =) Hassle yang mga ganyan. Hahahaha
    Dec 2003
    Quote Originally Posted by istan View Post
    meron.. .let me check it again later...
    nakalimutan ko yung name eh pero meron na nito... may denominations din ata na 100 300 at 500 eh.. unlimitxt card yata.. pero nakita ko na ito colored grey pa nga..
    check ko ulit... yung isang unit kasi na kapitbahay namin nag bebenta ng ganito..
    One is TXTCRETARY (or something similar). The thing is, you have to change your SMS Service Center. So, when you txt a message, it will be forwarded to their system and their system would then be the one to forward the message to your recipient. It is cheap but when I used it, the bad thing about it is that if your recipient replies in the number that sent the message, it will cost him/her P 2.50. Thing is, sanay pa naman din tayo na pindutin na lang ang reply button sa phones natin kaysa mahassle pa tayo sa pag create ng bagong message at ilagay pa ang number ng rereplyan natin manually. But, if your recipient can live with that (doing it the hard way or spending 2.50 for a reply), then no problem IMO.
    Dec 2003
    Quote Originally Posted by batang_raon14 View Post
    yan! thanks batang_raon14... eto nga yun..
    Thanks guys! This helps! A lot!
    Aug 2004
    here's how this works...
    UNLIMITED ACCESS TO ALL NETWORK services is a TEXT MESSAGE FORWARDING Facility outside of your mobile network to fully maximize subscription of UNLIMITED TEXT program of your own Mobile Network. Before using this card you must Subscribe first to your mobile Network's Unlimited Text program. then you need to enroll the name/number you want to text,
    Note: When your message is sent. Your message includes your Registered Name and the Number you registered. However, they will be receiving your message coming from your assigned gateway number. They won't be able to reply in the gateway no. IMPT: that they would still reply in your original number.You can enroll as many texmates as you want.
    Actually, that is an ILLEGAL service that they are offering.
    Their "gateways" are actually just prepaid phone numbers which the telcos can shutdown immediately if they detect a LARGE volume of incoming/outgoing messages.
Unlimited Textcard for use w/ Smart, Sun, Globe
