Results 1 to 8 of 8
    i have my Acer 1640z,,, lately nagkaroon ako ng problem sa touchpad ko. it was happened nung nag-copy ako ng file from laptop to mobile and it was not plug sa AC (kuryente). while i was transferring a file from laptop to cp, suddenly may nagpop up na message, nakalimutan ko yung msg. but something concerns with the battery... taz nung i close ko yung msg. yung touchpad ayaw naman ng gumana... i tried to plugged sa AC taz parang nag hang yung touchpad ko... then i have to re-start,,, doon na nag start na ayaw gumana touchpad... i tried to reformat and re-install xp sp2 pero eto napansin ko... everytime its not plug sa AC the touchpad works fine pero pag ikakabit ko na yung adapter nya sa AC saka ayaw gumana...
    ano po sa tingin nyo may problema dito... at ano ang solution... i just need your thoughts.. di ko ma figure out kasi problema neto eh...
    salamat po sa inyo...
    Feb 2005
    hmm...sana system restore na lang ginawa nyo ser baka nacorrupt lang system registry, anyway, try mo ser update driver ng touchpad, hth
    I think that it is power related ang problem, perhaps the ic for the power leading to the touchpad.
    naku po... delikado ata yung laptop ng misis ko ha... saka isa pang napansin ko... full pa yung batterry pero parang halos maximum na lang nya is 1 hour???? i think hindi na normal yun ano...
    Quote Originally Posted by shotokan View Post
    That is not normal nga seems like you are loosing power somewhere in the system so malamang hardware nga. Maybe it is shorting somewhere. Hindi yan madadala sa re-installation of drivers or OS or even formatting.
    Time to take it to your nearest Acer Service Center.
    thanks sa mga replies nyo guyss...
    sya nga pala... maganda ba talaga na dapat bang ma drain yung battery ng laptop... kasi eversince na nabili ko yun,,, di ko sya hinahayaang ma drain eh... tuwing gagamitin i plug it sa AC. the laptop is already 2 years old...
    Quote Originally Posted by box_type View Post
    actually, before i reformatted my hd... i've tried the system restore but it didnt help kaya napilitan akong mag reformat...
    hardware yan... malamang power supply or power regulator.
Ano sa tingin nyo may problema?
