Results 1 to 4 of 4
    Nov 2007
    to all techy guy out there i got a problem with my laptop .
    I have 3 PC at home and all connected to Internet of course they connect thru switch/hub the first time i use the laptop and connect to internet is good, but afterwards (2 hrs) the internet connection got lost
    all three units can connect to internet without problem
    the Lan card is working perfect i can ping other PC but pinging website (eg: yahoo.com) i dont receive any response
    what could be the problem and how can i fix it?
    the dhcp is automatic so the IP is automatically distributed
    Quote Originally Posted by jansky View Post
    Have you tried disconnecting the other 2 pc's and see if the lappy stays connected online?
    Feb 2007
    try this solution...
    go to "command prompt"
    type: ipconfig /release... your ip address will be loss
    then type again: ipconfig /renew..... your ip address will be renewed and see whether this works.
    are you connected via wires or wireless?
    if you are connecting via wireless, baka sa config ng router mo.
    kung wired, try mo yung solution ni nautica.
HP notebook with preinstalled Vista
