Results 1 to 10 of 12
November 25th, 2008 08:41 AM #1
hi ask ko lang paano po ba nakacopy ang entire contents ng harddisk ko to a new one? help naman po tia.
November 25th, 2008 09:15 AM #2
Software: Norton/Symantec GHOST.
You can look for it on the web and sometimes it comes "free" with certain computer motherboard software support CDs.
November 25th, 2008 11:02 AM #3
hindi naman po free kapag sa web. hindi ba pwde mano2 na lang without software?
November 25th, 2008 11:20 AM #4
November 25th, 2008 11:32 AM #5
You can't just copy/paste the files. It won't work that way. You'll need to buy some imaging software. One software that I know tell you exactly what you're doing and it works great is called "Acronis True Image" (www.acronis.com). Get the home edition one; works just fine.
Basically how this will work is you install the 250GB drive as a second drive (the 'slave' drive). Install the Acronis software on your old ? gb drive(you should mention how many gb your computer). There's an option in the software to "clone" your harddrive. Once you've cloned it to your new 250gb drive, you can swap it back around so the new drive is now the 'master' and the old one is the 'slave' (or remove the old one completely). Now when you boot up, your system will have everything like it was but all on the new drive.
If you're unsure how to make a drive a 'master' and/or 'slave', there should be some instructions that came with your new drive on the jumper settings. You can also google "adding second harddrive" or something similar and find plenty of webpages showing you how to do it.
Good luck!
November 25th, 2008 01:18 PM #6
anong data kelangan i-transfer? wala naman mga software? kung wala pwede na siguro copy paste. hehe
- Oct 2007
- 123
November 26th, 2008 06:04 AM #8I used a software called HD Clone... pwede din acronis. daming software na pang clone ng HD ngayon
November 26th, 2008 07:46 AM #9
- Sep 2003
- 102
November 30th, 2008 11:45 AM #10
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
