I recently purchased an iPhone5s. I just noticed that it gets hot when I' m using it. Ganun ba talaga yun? I have owned previous iphone models, never experience that.
Battery life is also very short (less than 24 hrs).
Help mga katsikot. Thanks
ganyan talaga ang smartphones when you use resource heavy apps like games. when it gets hot it means you're burning through your battery charge at a fast rate because your processor is doing heavy... ehmm... processing.
laptop nga nag iinit ,,pag gamit sa games at surfing iphone pa kaya,,
natural lang yan..pero bigyan kita ng tip..turn off wifi,saka 3g network.
ilagay mo sa 20% or 30% ung brightness mo..para maka tipid ka ng kaunti sa battery
Had my unit checked sa service center, unusual daw yung heat ng phone ko. Sobrang init. Hardware problem daw and needs to be replaced. Too bad, I bought my unit overseas. Di sya covered ng waranty sa Pinas. Ibalik ko na lang sa pinagbilhan ko when i go back on rotation.
Never ko naexperience na nag init ng ganun yung previous iphones ko from 3G to 5. Same lang naman ang pag gamit ko.
Naka off lahat ng background apps ko and i see to it na di namumultitask yung phone ko. Off this location services ko at bihira ako gumamit ng data services.
The back cover of these iPhones act like a huge heat sink. The phone may feel hot, but its actually running cooler because of the heat dissipation. This is why I do not have a folding cover for my iPhone. I just use it as it is.
On the iPad, I accidentally left it inside the car under direct sunlight. I thought "tostado" na iPad ko. But when I turned it on, nag prompt sa screen yung "abnormal temp" reminder. Tinutukan ko ng electric fan. After it cooled down, umandar naman.
