Ganda ng aux lights nito ah! (looks familiar...)
http://www.pbase.com/image/26045502
Sinakay pa sa truck yung LC. hehehehe.
OT: approaching those canals... saan ba dapat dadaan sa two canals or dadaan nalang sa gitna para maiwasan yung malalim na canal?Originally posted by Ungas
You should try to ride over them. Dapat liko pakaliwa ang LC para higher ground pa din. That is kung hindi sobrang lambot ng lupa. Otherwise, sagasaan mo na! hehehehe.
hehe yun don ang iniisip ko para at least higher ground safe pa yung diffs
i like your style bossing "Otherwise, sagasaan mo na! "
ahihihi
biglang vroooom hehe
kasi usually nakikita ko sa mga karera doon parin dumadaan sa mga canal - naguluhan ako ng konti hehe
Hindi naman tayo kumakarera. Recreational off-roading lang.hehehe.
If you could check the mud the better, kung malambot yung gitna at gilid mas may chance kang maipit. Better follow the mud trail pag compact na yung muds, less damaging. But if the mud is soft and water, lock those diffs and pray that 2nd gear will be sufficient enough to pass thru it.
ungas nag browse ako sa pbase ni ECG
may nakita akong pics ng nag trail sa delata 5
(last year)
sama na natin sa thread dito
http://www.pbase.com/edwincgo/porci_delta5
Arrrghhh... Delta 5 again! I have some unfinished business with that trail.
Btw, may nakita akong pogi:
http://www.pbase.com/image/26046464
The pictures were taken at the notorious tatawiran trail, a 8 kilometer non stop mud climb with several hundred foot drops on the side depending on what direction you are headed, I just arrived from there this morning, from a very hardcore trail ride.
tara Delta 5 matagal narin walang offroad hehe
tigang na ba?
tara glenn,ako naman ang navigator mo this time
let's go ungas???
afrasay, isabak na natin yung zuk!
olive drab, mas ok ang bstone sa lahar
Ot na pala ako
