Results 1 to 12 of 12
    Yesterday, I had our driver drive my AT cuv and I noticed he hardly put it on neutral during traffic and that he ALWAYS presses the shift button when moving it from D to N.Tinanong ko siya bakit and he said yun daw iba naming AT's pag tumatagal, pumapasok na sa R o P from D even without pressing the shift button. He surmises this is because of shifting from D to N without pressing the shift button.Ano ba talaga cause nung pumapasok sa P o R from D kahit di pine-press yung shift button? How could this be prevented?
    Jan 2003
    Labo yata nun a. If, for example, you're in D and you want to shift to N, you'd be more in danger of going past N and into R or P if the shift button was pressed.
    Jul 2003
    Quote Originally Posted by Yoda View Post
    Its better not to put it in N neutral rather put it in P parking. Kung hindi naman sobrang traffic hindi ko na ginagalaw ang shift laging D drive apak nalang ng brake. Ang delikado dyan pag nilagay mo sa N tapos magkamali ang driver nailagay sa R reverse sigaradong bunggo ka aatras ang car mo.
    Quote Originally Posted by nap123 View Post
    bad advice. put the tranny in P only when you are parked in a proper parking place, never when you are waiting for a green light in traffic. first, if you put it in P e di dadaan ka sa R (P-R-N-D) para ilagay sa D. dyan madalas magkamali pag naka-stop ka sa traffic light and then green light na, baka malagay mo sa R at maatrasan mo yung nasa likod. second, and more serious, if you have it in P and your car gets bumped from behind, warak ang tranny mo. remember that the Parking brake is a set of stationary gear teeth that mesh into the gear on the drive shaft to prevent the shaft from turning. pag naka-mesh yan at may bumangga sa car mo e guess what will happen to that shaft. if the traffic stop is long i suggest better put in in N and then set the hand brake.
    i do not even put it in P when i am parked on an incline. pwede (meaning not always but possible) maipit ang parking brake pag nasa incline ang vehicle. the stationary gear will get stuck due to the weight of the car on the incline. while parked, ilalagay sa P while on an inclined road, shut off the engine, then pag start ulit ng engine di na ma-i-shift kasi naipit na yung Parking brake. what i do is just point the front wheels to the gutter and use the hand brake.
    May 2004
    Ang ginagawa ko pag mag-papark incline man o hindi, lagay ko sa N habang naka-apak sa brake, apply the handbrake then angat mo yong paa sa brake to make sure na di mag-roll forward or backward. Pag secure na yung car, lagay ko naman yong lever sa P. At least yong handbrake ang pumapasan ng weight ng sasakyan at di yong tranny.
    Jul 2006
    Quote Originally Posted by Wouie View Post
    ganito din ginagawa ko. napansin ko kasi dati na mahirap alisin sa park kung di muna hahayaan na kusang mag roll ang kotse.
    gawa ko din ito pag di masyado matarik ang incline. pero minsan kasi nasa parking ako ng mercury drug sa proj 8 (tarik dun, more than 30 degrees siguro) di ko nabatak ng husto yung hand brake kaya hirap alisin sa P later. di naman ipit pero need effort din, so since then ingat na ko sa incline.
    hmmm very helpful tip. Ito pala ang problema ko kasi inclined yung harap ng house ko at palagi akong hirap transfer from P to D Santa Fe ko. First time ko kasi magkaroon ng AT car. But I do put it in N during heavy trafic. It is gated kaya nil ang error to put it in R accidentaly. Sanayan din kung minsan
    Jan 2003
    I've seen people do this even in stop-and-go traffic. If you're behind one of them, they're easy to spot because their back-up lights would flicker momentarily.
    indeed
    no offense, but you driver is talking non-sense.
    hindi yung mangyayari unless na mis-aligned yung shift cable. hindi basta-basta masisira yung shift lock...
    mis-aligned is not caused by not pressing the button, it only happens when the shift cable is damaged or moved...
    still same procedure... you do not need to press if you go from D to N...
AT maintenance?
