Results 1 to 10 of 13
Threaded View
May 14th, 2004 02:47 AM #1
Could this be a worthy sucessor to our tried and tested 6250's?
Presenting the Nokia 5100:
From http://www.nokia.com/nokia/0,8764,4509,00.html :
Phone Features
Protected against splashes, dust, and bumps
Tri band (EGSM 900/GSM 1800/1900)
High-resolution color display
Downloadable personal applications via Java™ technology
GPRS (General Packet Radio Service
HSCSD (High Speed Circuit Switched Data)
WAP 1.2.1 browser (via GRPS or CSD)
Multimedia messaging with compatible devices
Flashlight
Stereo FM radio
Integrated handsfree speaker
Polyphonic (MIDI) ringing tones
Colourful wallpapers
Stopwatch, alarm clock
Digital clock screensaver
Countdown timer including interval timers
Calculator, currency converter
Calendar, to-do list
Calorie counter
Thermometer
Automatic volume control
Sound meter
Connectivity options: IR and cable
Full Specifications
Size
Weight: 104 g (with BL-4C battery)
Max. dimensions: 108.5 x 49.5 x 22 mm, 89 cc
Display
Supports 4096 colors, 128 x 128 pixels
4-way scrolling
5 lines for text in basic mode with 16 pixel font
User adjustable display brightness
Color wallpaper
Durability
Xpress-on™ shells provide protection against splashes and dust
Also the inner module has resistance to splashes and dust when the shells and key mat are mounted
Improved durability to offer protection against accidental bumps
Bottom flap gives extra protection for the connectors
Memory Functions
The following functions use shared memory that is dependent on the data quantity per item and shared memory available at a time in the Nokia 5100:
Phonebook - up to 300 entries
SMS - up to 150 text messages or 50 picture/concatenated messages
Calendar notes - up to 250 entries
To-do list - up to 30 entries
Fixed ringing tones - 11 preset, not removable
The following features share a memory pool of 725 kB:*
MMS messages - max size 45 kB per MMS message
Ringing tones in Gallery - 20 preset, all removable
Images - 10 preset, all removable
Java™ applications - 4 preset, max download size 64 kB per application
Messaging
Text messaging: concatenated SMS, send and receive up to 3 messages, (459) 160+146+153 characters, in Unicode 70+63+63 per message
Predictive text input: support for all major European languages
Templates: quick and easy sending of pre-defined messages
Picture messaging: send pictures with text to other compatible phones. 10 predefined pictures in the phone, 5 empty for downloads, all replaceable.
Multimedia messaging: receive messages containing a text, an audio file and a image, which can be saved as wallpaper and ringing tone; send and forward messages containing images and text to other compatible phones.
Mobile Chat: based on standard SMS. All previous written messages from both persons are visible on screen. Chat messages are not saved on the SIM card.
Ringing Tones
21 polyphonic and 10 monophonic tones preinstalled
Java™ Technology Support
Support for download of games and applications
Converter application (supports most common currency, area, length, mass, temperature, and other conversions)
Sky Diver, Triple Pop, and Bounce games
All user removable
Call Management
Speed dialing: for up to 9 names (key 1 is always for voice mail)
Last number redial from dialed calls list (dial-key brings out the dialed calls list)
Automatic redial (max 10 attempts)
Automatic answer (works with headset only)
Emergency calls to 112 without SIM-card and with key locked phone
Call waiting, call hold, call divert, call timer
Automatic and manual network selection
Closed User Group
Fixed Dialing Number, allows calls only to predefined numbers
Tri-band Operation
EGSM 900, GSM 1800, and GSM 1900 networks in Europe, Africa, Asia, North, and South America
Automatic switching between bands; please check roaming possibilities from your service provider.
VinFast VF 3
