I hear it usually sa front right side, what could be the problem.
Bearing kaya?
Kung bearing kailangan ba palit o repack, meron bang bearing din yung likod na wheel (pareho ng front) ?
Bearing kaya?
Baka naman kailangan lang ng greasing at our favorite Shell Retiro?
Sumasabay ba sa lubak o continous siya as you roll along?
Pwede ngang bearing. Si afrasay ni-repack niya ata yung bearing ng Pajero niya. Siya na mismo gumawa.
Alam ko wala kang kailangan palitan sa likod, eh. Yung Pajero namin dati 1988 model pa wala namang nasisira sa rear suspension.
Either faulty Wheel Bearings OR some foreign material is stuck in your brake pads OR your brake pads already reached the end of their service life :mrgreen:
Rediesel::: What is your ride? Type of suspension?
As sir OTEP was saying it could be your wheel bearing and sir pajerokid's braking solution. Or your suspension bushings that might need lubricating.
It is easy to check for wheel bearing damage, run your vehicle 20-30 km/h then put to neutral, no gas pedal, free wheeling then listen if the sound hums. (Broke wheel bearings hums while rotating, like running mud tires on asphalt.)
For suspension bushing check try it on humps. If it squeaks while rebounding, I may then suggest go to your gas service station ask the service if they could raise it and spray used oil on all your moving suspension parts, especially the rubber bushings.
Hope this helps. :D
PS.
Different vehicles differ from various wheel bearing sizes, and usually front bearings are not the same with the rear wheel bearing. Repacking it will prolong its life a bit, but it will not run as smooth as a new one.
Ungas,
RED Mitsubishi Adventure ang ride ni RED.One of the original diesel boys iyan.
Hehehe.
I remebered one more thing, baka naman sa hood galing yung squeaking sound, usually hindi aligned ang hood spacers. :D
Nice to meet you sir Rediesel, hope to meet the rest of you guys! :D
Correct me if I'm wrong, Mitsubishi Adventure has double wishbone with coil springs?
yup its double wishbone coil spring front suspension.
I hear the sound when its rolling.
suspect ko nga bearing e.
brake pads hmmmm kakapalit pa lang e (mga 5000 to 7000 kms pa lang)
the old brake pad was used for more then 20000 kms.
thanks sa lahat ng suggestions.
one more question.
SAAN maganda magpaayos at magpapalit ng bearing???
P.S. Mga tol MAGANDA DAW yung Shell Helix na for Diesel pino takbo at clear yung langis I will try it tomorrow when I have my oil change
ser,
baka lumuwag yung turnilyo sa bearing.........
yung saken kahit may lock twice ko na tighten eh lumuluwag. baka nung lumuwag na damage yung bearing.
try to lift right side of the car tapos shake mo kung maluwag. kung lumuwag yan delikado. napapnisn ko kasi pag lumuluwag yung sakin parang iba ang tunog pag nalulubak parang may umaalog.
salamat sa lahat ng suggestions.
pinatingnan ko parang hindi daw bearing try ko muna palinis yung brakes baka merong umipit na foreign body.
hindi kasi pirmis yung sound e pag bearing di ba pirmis yung sound tapos escalating habang bumibilis lumalakas.
e minsan nawawala e.
anyway TY for the suggestions.
Rediesel,
Kamusta na? Hindi na naulit yun AKU natin. Anyways back to the subject.
May small metal na naka protrude, although naka recess pag makapal pa yun brake pads. When you are rolling and manipis na yun pads mo, nakatukod yon metal sa disk and tumutunog yun, kinda like may tansan na nakadikit sa disc. When you step on the brakes magsasabay na yun pads mo and your metel indicator, kaya nawawala. Hope this helps.
ano ba yan one post per day...
...madaming work:cry:
Rediesel,
Dun ako sa talyer ni Glenn sa Kamias nagpapatingin, eh. Kung galing naman ako ng school, sa Wheelers suspension house sa Banawe ko pinapa-check.![]()
