Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jun 2004
    ano kaya pinaka softrider pick-up except F150,Explorer thx..>>
    May 2004
    for me its TOYOTA TUNDRA!
    sa local new strada
    Humvee na pickup body? :D
    ford ranger...
    Strada
    Jun 2004
    ano feed back nyo sa frontier, Dmax, Hilux 4x2..>>
    Jun 2004
    ano kaya softrider na front suspension for pickup TORSIONBAR or Tipical coil spring hehe..>>
    ranger din ako
    Feb 2004
    what do you mean by soft rider? yung best/smoothest ride? or yung di pwede pang offroad dahil masisira kaagad? (or softroader ba yun?)
    andy
    Originally posted by JAYarc
    ano kaya softrider na front suspension for pickup TORSIONBAR or Typical coil spring hehe..>>
    Di hamak mas malambot ang spring rates ng torsion bars kung ito ay OEM spec. Independent Front Suspension setups have the smoothest ride, a sedan-like if I may compare.
    Kaya nga ang Mitsubishi nilagay nila sa Pajero gen3 Independent Rear Suspension setups. Thought the downside will be limited cargo weight capacity compared to coils-solid axles and leaf sprung-axles.
    Isuzu still utilizes its IFS setups on pickups and SUVs line up.
    isuzu pick-up
    Jun 2004
    softrider na for comfort..>>
    mala limooh kung pwede
    Jun 2004
    sa Torsion bar parang mahirap magpalit nito, at sa ka wala ata after market available na diff. spring rate fixed lang siya..??
    Jun 2004
    yung mismong spring ata nung Torsion bar eh yung parang tubo ata yun ba yun..?
    JAYarc::: You were asking for smooth ride and comparison was given, altering for aftermarket parts on torsion bars is another thing.
    Yes, yung tubo na mismo ang may load when mounted instead of common coil or leaf springs. Medyo limited nga ang modifications na magagawa, but aftermarket parts are abundant in other countires. Modifying torsion bar's spring rates are easily adjusted by turning the bolts in for more stiffer ride. But you will have to reset the whole bar before achieving the correct lift. Stiffer spring rate will be attained if the nuts are simply tightened from OE spec.
    Jan 2004
    medyo bias ako pero, i'd say i'll go for isuzu. of the 3, next yung frontier, then last yung hi-lux
    Jun 2004
    mas okay sakin strada, i ride nissan frontier matagtag kahit puno na kayo sa loob, strada suabe ang ride
    Jun 2004
    limitted pala mods ng torsion bar hehe...>>
    4x2= 1. Mits. L-200
    2. Ford Trekker
    3. Toyota
    4. Isuzu Fuego
    5. Isuzu D-Max
    6. Nissan Frontier
    4x4= 1. Mits. Strada
    2. Ford Ranger
    3. Toyota
    4. Isuzu Fuego/Dmax
ano kaya pinaka softrider pickup?
