Results 1 to 5 of 5
    Dati, meron akong naririnig na relay (glow plug relay?) mga 3sec sa may dashboard ng paje after turning the ignition key. Then I could turn it fully to start the engine.
    Lately, nawala yung sound ng relay kaya di ko alam kung sira yung relay. I turn the key to start anyway and I think yung lakas lang ng battery ang nagdadala para mag-start yung makina. Sometimes it takes two tries to start. Relay nga lang kaya ang problema nito (which means the glow plugs do not get their power supply?) Is it easy to D.I.Y. (replace relay)?
    Nasa P1,200+ ata yan, you can replace it yourself.
    baka mismo ang glow plug, baka pundi na!
    Jan 1970
    sometimes i also encounter that nawawala yung sound ng tick.. pero bumabalik naman... sometimes din.. matagal ang sound.. mga 7 seconds after turning the ignition to ON. ano kaya problema... glow plug din ba..? pero 1 click naman kahit no tick sound ng glow plug relay..?
    Maybe the GP relay is just loose. Happened to me more than once already. The GP is attached to the battery terminal itself. It's the little black box.
Glow plug relay?
