Here's the situation:
My idle speed without a/c on is set to 850 rpm. As soon as I turn on the a/c or when the a/c compressor engages if the a/c is on already, the idle rpm goes to 1000rpm as compensation. Afterwards, when the a/c compressor automatically switches off kung malamig na or if I turn off the a/c compressor manually, the idle drops to about 500rpm before it slowly rises back to 850. Takes about 4-5 seconds in going back. Parang mamamatay tuloy ang engine and you could feel the vibration na. Well, di naman gaano ka worse na I have to step on the accelerator pedal to prevent the engine from stalling.
I tried increasing my idle speed to about 900 or even 950 pero same pa din ang problem. I asked my mechanic in Bacolod about it and he said to try cleaning the idle speed screw coz sa vitara the idling rpm is adjusted by turning a plastic screw near the throttle body that acts to regulate the amount of airflow. I removed the screw and checked its tip and there were some carbon deposits. CLeaned it and reattached it pero same pa din ang problem.
Someone suggested na baka it could be a vacuum hose problem that connects the a/c compressor to the throttle body. Is this logical?
Btw, I changed my sparkplugs already since malapit na 50K pms ko and hoping that it might have been the source of the problem pero ganun pa din.
All your inputs would be highly appreciated. Thanks!
