Results 1 to 20 of 20
    Apr 2004
    Mga Sirs.
    Wala ba pong problemang idudulot kung ibabalik ko sa mineral based oil ang Diesel Adventure ko. Nag-try kasi ako mag synthetic nung 5000Km checkup ng sasakyan ko (at paakyat kami ng baguio nun eh). Kaya lang ang mahal nga talaga ng synthetic. Akala ko kasi same din ang gastos ko when I compare having to change mineral based oil twice (every 5000Km) to once with synthetic (at 10000Km). Not so, I discovered. Eh, balak ko nalang tuloy na bumalik sa mineral based oil. Oks lang po ba iyon? Wala po bang issue sa seals and stuff?
    Follow-up question, how about kung papalit-palit from mineral to synthetic, will there be problems caused?
    Thanks!
  2. FrankDrebin Guest
    Oks lang. Ganyan din ako dati. Balik sa mas murang langis. Gamit ko pa dati Mobil Delvac. Ngayon Delo Gold Multigrade.
    Jan 2004
    thanks for the input. kasi malapit na rin akong mag change oil e. buti na lang nakita ko itong thread na ito. :D
    A mechanic used to tell me that switching back to mineral based oils from synth ones will require flushing.
    While mineral based oil users switching to synth oils just switch. I don't have the facts to prove their claim, maybe the oil gurus here can help you more.
    Apr 2004
    What is "flushing"... I mean what else is done during flushing other than draining the oil?
    hmmn question din po mga gurus...pag ba hi-mileage na ung sasakyan lets say 100000 kms plus advisable pa rin bng mag synthetic oil?
    Pag sinabing flushing, may mga active ingredients/fluids na sinasama muna sa old oil para pag alis nito nililinis na rin daw ang mga naiiwang particles ng synth oil. Before draining out the old oil.
    I would assume that your engine has been well taken cared of. Kung maganda pa ang combustion, at dati ka nang gumagamit ng synth oil why not?
    With regard to high mileage engines, as long as the synth oil visousity is on the thicker side, oks lang. There are synth oils with thin viscousities and this may cause leaks.
    On synth vs. mineral, its still adviseable to change every 5K given our weather and traffic conditions. If a car uses synth and changes every 10K, the oil filter should still be replaced every 5K.
    On flushing, try to use Caltex Power FLushing oil. I was told before that those 5 minute engine flushes can be harmful to the engine internals/gaskets.
    Jul 2003
    I think its the other way around that requires flushing. That is when we switch to Synth from Mineral.
    This is so because mineral oils must've left some deposits in the engine that will eventually mix with the synth oil. The deposits are caused mainly by the uneven sizes of the oil particles constituting the mineral oil base. This will lessen the benefits we get out of the synthetic oil since the deposits will just circulate in the system together with the synthetic oil.
    I believe switching back to mineral oils will not need flushing anymore.
    It can be likened to a drinking glass once containing orange juice. Then you wanted water. Then you wanted orange juice afterwards again. If you wanted to have the water as pure as possible, you would've washed the glass first.
    I stand corrected, di ko na po kasi maalala yung sinabi ng mekaniko dati. :D
    Jun 2004
    Mar 2003
    Tama si vinj, nagswitch din ako from mineral to synth. first 2 change oil ok pa konting pawis lang ng oil. after 3rd change oil ng synth may tulo na sa sahig mga 3 drop overnight parking. sa valve ccover and sa turbo oil line galing. i used 5w-30 oil by petron. next change oil balik mineral na uli.
    ako 2 years na gamit ko mobil 1 synthetic. no problem pa naman so far. i just change every 5,000 o 6 months which ever comes first. mas maganda talagfa hatak ng 4d56 ko pag synthetic.
    Apr 2004
    So basically, i shouldn't have any worries when I switch back to mineral (leaks or anything).
    KCboy, every 5000Km change mo ng synthetic? Wow, I guess if you can afford P5K+ each change then it really is worth it. Ako, hindi ko na kakayanin and with diesel going up as well... I have to go back to mineral talaga.
    Signs of age? hehehe j/k
    vinj::: Bwahaha! It was a loooong time ago, about 3-4 vehicles behind. :bwahaha:
    Feb 2004
    ako rin, bhala mabagal ang pajero ko, basta mineral lang muna ako.
    maraming bags of cement ang mabili ng P4000 diference between mineral and synthetic
    andy
    rafraf,
    ako lucky kasi i only pay about 3,000pesos for 6liters of mobil synthetic, fuel n oil filter n 3 liters of regular oil for flushing. labor pagawa ko sa tao ko sa planta so it's cheap for me to use fully synthetic.
    rafraf,
    Feb 2004
    i saw in the papers, 100 pes0s na lang ang labor ng change oil ng mitsubishi, totoo kaya yun or pagdating ng bil, mayroon pa ring "hidden" charges?
    andy
synthetic back to mineral
