Results 1 to 17 of 17
    pa service ako for 35k pms sa alabang last week but b4 pumunta ako nag lagay ako ng marking to be sure na ginawa nila yun dapat inspect and adjust. so after 5 hours ok na raw auv ko so bayad ako den inspect ko kung gnawa yun dapat gawin specialy valve clearance. suprise ako kasi yun seal na inilagay ko di man lang nagalaw so its means di nya inspect and adjust kung dapat adjust. call ko yun service advisor ask ko kung inspect ng tech. he said yes sabi ko sure ka ba check nya sa serv.report di daw ginalaw so ipinasok ulit auv ko inspect nila sabi sa akin kasi ok paraw yun andar ng makina kaya di na inadjust, sabi ko diba nakalagay dun INSPECT AT DI PAKINGAN LANG yun makina bago adjust and valve clearance.
    hayop talaga sila every 5k service ko laging hingi na lang ng pasensya ang serice superisor sa akin. kaya dapat sa lahat ng nagpapaservice inspect nyo sasakyan nyo kung pinalitan ba ang dapat palitan and na inpect and adjust yun dapat inspect mahirap ng magtiwala buhay nyo nakataya.
    sorry haba share ko lang experience ko.
    jake
    I had the same experience in my Strada but it's during the 30k PMS. Kasama sa PMS ang adjustment ng clutch free play pero di inadjust. I brought my truck back sa casa after 3k and reported it and it's a good thing they adjusted it without charge. It's in CarWorld Marilao. Very good service.
    jake, di ba xwind ka din? san ka nagpapaservice? sa inteco edsa kasi, I can go to the service bay and watch over the mechanics while they're doing the PMS. sa iba yata di allowed yun. although i'm not saying na ok ang service ng inteco. what i noticed, di nila sinusunod yung checklist sa manual. pero at least, nakikita ko that they do adjust the valve clearance every 5K PMS ko. the basic things that they do every 5K are:
    - clean air filters
    - clean fuel filter/change every 10k
    - change oil/change oil filter
    - clean water separator
    - adjust valve clearance
    - pag masipag yung mechanic, adjust handbrake mechanism
    tapos, every 10 km, or 20 k ata,
    -change gear oils.
    -clean brake pads (both front and rear)
    yun lang ang gusto sa service center ko ngayon even though i've heard and seen some bad feedback from them. i can freely inspect what they're doing and you can talk to the mechanics para makakuha ka ng tips.
    Malaking plus factor for me ang mga casa na pumapayag na makit ayung car habang inaayos/service.
    On the service of Isuzu, when i took a look at the Crosswind before with my dad sa Q. ave, pinatingin sa amin ang kotse sa service area (sa customer na nagpaservice) since nakalock ang showroom units (sunday).
    when we called the next day to follow up on a test drive, we were told that we had to reschedule since "the owner already clainmed his car" sa service :?
    rsnald,
    sa isuzu alabang di alowed lapitan yun car mo dun ka lang sa customer lounge pero kita rin kung ano ginagawa mo sa car mo. kaya yun mga dapat palitan and dapat inpect nilalagyan ko ng marking para alam ko na inspect nila. ok din naman sa alabang kaya nga lang dapat alam mo kung ano yun dapat nila gawin para ma inspect mo pagkatapos.magkano labor ng 35k service sa inteco sa alabang kasi is 1,600.
    napalitan na ba yun radiator mo? sidings sa driver side ko wait pa ng stock.
    ot. sir nakapag pa register ka na ba ng 2003? wat is the result of ur immision test?
    Quote Originally Posted by jake
    rsnald,
    35K PMS 1670 - may butal lang ng konti
    tapos na ko ng 45K going 50K nako.
    radiator replaced twice already but now leaking again!
    yes tapos nako magparegister. 0.65 opacity reading ko. way below the 2.5 max specs. although nag spike din sya ng 1.0 ata.
    rsnald,
    san ka nagpa emission test?
    wala ka bang ginawa sa xto mo kc b4 sa akin last year to be exact nag over 2.5 sya den so pinabalik na lang ako ayusin ko muna raw so ginawa ko hinugasan ko lang mufler nya den binalik ko on the same day sa ibang counter yun nakapasa na sya.
    thanks...
    rsnald,
    thanks...
    sa may Pioneer, mandaluyong ako nagpatest. 1 month old oil (IGMO), I cleaned my stock air filters and I was using cocodiesel additive (home brew :D ) a week before the test -- 1 liter per full tank. Pero I doubt if the cocodiesel helped at all. No cleaning of muffler. yun lang pasado na.
    after I passed, di nako ulit gumamit ng cocodiesel but would like to use it again.
    Jake, sa isuzu cavite allowed din lapitan ang sasakyan habang nag-pms. Although mukhang ok din sa inteco, baka lang kasi mas malapit sa yo ang isuzu cavite. OK din naman ang service nila sa XTO ko.
    FYI.
    jake,
    di mo sinabi nagparamdam ka sa mga taga Isuzu Alab...... galing ah..... minarkahan mo yung valve clearance... pero di nila ginalaw...
    Teka sino Service Advisor mo don..... makachickanhan nga...
    Sa IAB - ayaw palapitin.... kasi pampagulo raw mayari... dami tinatanong at dami pinapasingit sa trabaho.... takutan na lang yan....
    Mabuhay ka... Rsnald.... musta na....
    TEAL, mabuhay ka....
    rsnald,
    thanks
    teal,
    thanks sa info try ko rin siguro next time dito lang naman ako paranaque.
    boknoyxtrm2001,
    yes sir yun cover ng valve ang nilagyan ko ng seal.
    service advisor ko kahit sino basta pagdating ko ron kung sino avilable pero masmalimit si TAMMY pero follow up ko rin kay BOBOT kasi sya hingi pasensya pagpalpak yun service tao nya.
    Sir Boknoy, tanong ko lang po: pwede po ba magpa 35km pms excluding air con evaporator cleaning? Sabi kasi sa akin ng isuzu cavite di daw po pwede dahil di nila maipapasok sa computer for billing. Accurate po kaya ito? Very satisfied po ako sa service nila sa XTO ko pero I'm having second thoughts sa 35K pms dahil sa concern na ito. Ayaw ko po ipa galaw air con ko dahil wala naman pong problem plus ingat na ingat po ako sa dust sa loob para di dumumi ang evap plus regular po DIY pressure washing ng condenser ko. Right now, nasa 34,600+ na po mileage ko & sa September'03 pa po mag2years XTO ko. Thanks.
    jake,
    EB na ....... taga las Pinas lang ako.....
    Si Tammy ok yan.... tsaka si Rowen.... mga kakwentohan ko yan..... sabihin mo low power..... tignan natin kung gagalawin nila... they set the valve clearance 14 sa hindi ko maintindihan bakit ganon ang setting... it should be 16 which results to low power... ayaw talaga nila gumalaw....
    TEAL,
    Ang Software kasi nang IADI ay predefined base sa KM PMS mo... kasi ako... tinigil ko na ang pagdedealer (as in naman alam kung bakit) so di ko na nasusundan... washing condeser rin is not enough kasi may evaporator pa yan... palinis mo na ......
    Pinasok ko lang ang sasakyan ko nung 1,500 at 5000 PMS tapos 20K (dineclare ko low power) wala lang tune up lang ang ginawa.... e malas nila may blue book ako.... sige gawa sa pagawaan bayan... ayun ayos na...
    pero bait yan si Rowen at Tammy.... Pagawa mo na lang sir teal
    Quote Originally Posted by TEAL
    pag kakaalam ko sa 35k di pa kasama ang cleaning ng aircon ckeck lang sya sa 40k pa sya kasama pero ako nag pa service na ko sa mga authorized center ng denso dito sa las pinas.
    sir boknoy,
    talaga sir taga lp ka lang, me sav.6 parq. san ka sa lp.? nakakuha kana ng sticker for friendship road
    yup ok yan si tammy taga parq din yan ups 5 ok naman service advisor ng alabang kaya lang ang poblema yun mga technician nila.
    Ano ba naman iyang software ng Isuzu na iyan? Hindi adjustable! Either that or pineperahan ka lang nila.
    As the consumer you have the right to avail or refuse their services a la carte. Hindi ganyang parang value meal.
    Sa Nissan at Kia hindi naman ganyan. Pati sa Commercial Motors pwede ka mamili. Makikita mo pa habang binabawas sa computer yung mga items (e.g. you brought your own materials like oil, sandpaper, etc.).
    Sakto Boss OTEP!
    Baka naman may nakakabasa dyan na taga ISUZU, you might want to consider this concern. Pano kung gusto lang talaga ng customer e basic scope of work? e di ang choice lang nya is to pay in full kahit di kasama ang aircon cleaning .........or to go somewhere else and void the warranty.
    Jan 1970
    yung ate ko bumili ng mitsubishi spacegear diyan lapit sa greenhills. Dumaan kami one day para ipakita sa min kung ano hitsura nung space gear. Pumunta kami sa showroom nila tapos pinakita sa amin yung isang space gear na nakadisplay, so tinignan namin lahat pati interior. Nung dumating yung kakilala ng ate ko, sinabi niya na yung tinitignan naming unit pala yung ibibigay sa kanila. Biruin mo bago pala nila i-release yung unit eh yun yung idinidisplay nila sa showroom. E ilan na nag-labas-masok dun.
35k pms
