Results 1 to 20 of 20
    hindi ko alam kung sa workshop or dito sa diesel thread ito.
    anyway, i have kasi a 2004 starex svx with intercooler turbo and just got it last december 2005. i read the manual and its says that i have to wait for the turbo to cool down before turning off the engine. but it doesn't says how to cool it down? so far, i've been using it for out of town trips during weekends and i'm quite worried everytime i'm turning off the engine. tsikoteers, how will i know if the turbo has cooled down na?
  2. #2
    1-2 mins idle..pwede na siguro yan..if you have budget, turbo timer kuha ka...kahit patay mo na ung susi, di agad mamatay makina for the set time
    Quote Originally Posted by alwayz_yummy
    thank you po sa reply.
    idle for some minutes lang pala? i'll try to inquire din for a turbo timer.
    how does it look like kaya? any idea how much does it costs kaya??
    many thanks again!
  4. #4
    depende, may used, mga 1.5 thou, pero new ones may 3 thou up..depende din sa brand... sabihin mo turbo timer sa banawe, ok na un...pero may babaguhin sa electricals mo most likely...pero protection sa turbine ang purpose nito,e... mayroon sa kabilang site na turbo timer, pa-install mo nalang...
    May 2005
    Quote Originally Posted by zero
    many thanks again!
    Idle with the aircon off and everything, except with only the engine running.
    This is how a turbo timer would look like. There are many different brands and model out there. The one on the pic is the one made for the Fortuner.
  6. jagxtrm Guest
    ok yng turbo timer ng fortuner ah...
    pwede rin kaya yan sa innova d4d? same naman buttons nila. saan kaya makakabili & install nyan?
    yep pwede sa innova, hi-lux and may pang d-max rin na swak sa orig openings.
    walang baguhin sa wiring they will just tap in.
    Sep 2005
    ARB, saan makakabili nyan. Kailangang lagyan ko yung dmax ko.
    If you're just driving in the city, just don't drive too hard or hit the high rpms when you're near your destination already then just letting the car idle for around 20-30secs (even with the a/c on as this has no effect on the turbo) should be fine.
    If you've driven long or hard, idle for around 1.5 to 2 mins.
    There are some car alarms that come with a turbo timer feature.
    I was just thinking... vehicles with turbos aren't the best choice for persons learning to drive since they may not get the gas-clutch coordination correct, thus leading to stalled engines and throwing the mandated turbo cooldown requirement out the window.
    Ang tanong ko ay, pag may turbo timer ba ang kotse, maiiwasan ba ang pagtirik ng makina pag mali ang timpla mo sa gas at clutch?
    nope, it's still based on leaving the engine on for cool down * neutral. so if you engage it in 1st gear and let go of the clutch, mamamatay talaga yung engine.
    here's my greddy aftermarket turbo timer:
    Aug 2004
    ARB, magkano kaya ang turbo timer na yan? pwede din ba sa trooper (4jg2) ito? hindi ba magkakaproblema yung alarm (cobra) pag nilagyan ng turbo timer? thanks.
    Aug 2004
    Quote Originally Posted by mikey177
    Actually, it only becomes a problem if the engine is turned off hot and stays off. If it stalls and is started again right away, then there's no problem...
    Okay, thanks for the clarification, ssaloon. And thanks, niky, for the tip on immediately restarting the engine.
    Feb 2006
    Ako ginagawa ko pag malayo na puntahan nang Trekker ko, usually mga 5-10mins ko ina-idle. Pero pag dito sa city mga 1-2mins lng din. Para tumagal ang buhay nang turbo.
    May 2005
    what will hapen if u didnt cool down your turbo?
    toast seals, burn bearings...actually di naman agad masisira ang turbo mo kung di ka mag cool down. di lang magtatagal ang buhay nito. and just like what vinj said. pag city-city lang you seldom get to run your turbo. sa highway naman well you don't usually go from 120kph to 0 kph in 5 secs. syempre when approaching, say a gas station along the highway, eh mag slow down ka muna in effect nag cocool down narin ang turbo nito.
    Jan 2004
    ako ang ginagawa ko, after highway run, e medyo mabagal ang speed ko, until i reach home.kasi may mga 5 minutes pa ako from NLEX e. saka isa pa i don't drive that fast 80 km/h max. ok lang ba iyon?
    May 2005
    Saan ba galing ang lubrication ng turbo? sa engine oil ba or may separate oil container? Would it help kung synthetic oil ang gagamitin kung naka turbo because of its wide range of viscosity e.g. SAE 0-30 or 5-40.
    Quote Originally Posted by nansky
    Oil for the turbo comes from the engine.
help: how to cool down turbo?
