Results 1 to 15 of 15
    Aug 2003
    ilan km ba dapat mag palit ng timing belt??
    Jan 1970
    depending on manufacturers, it ranges from 70T to 100Tkm. i just changed mine at 75Tkm, and the belt still looks good. timing belt replacement is a very cheap thing to do, but if it breaks on you, it will cost you a whole lot!
    Aug 2003
    thanks slip-slick,, ride ko kasi crv nasa 70tkm na
    Jan 2004
    follow the owner's manual. 80K sa civic ko. ok pa yung itsura. i think sa mazda 100K pa. mazda owners, correct me if i'm wrong.
    maraming sisirain kapag napatidan ng timing belt kaya di dapat i-neglect yan.
    Mar 2003
    dati meron kami gen 1 crv nakalagay sa manual 80k km ang palit ng timing belt.
    May 2004
    pwede mga 70-80k.
    better safe than sorry...
    pag naputulan ka ng timing belt, tatama valves mo sa piston causing it to bend. kailangan mo na magpa o/h.
    Nov 2003
    usually manufacturers recommend between 70-80t kms. kung chain gamit over 100t kms kaya pa.
  9. #9
    diba yung chain type di na pinapalitan, usually pag sobrang tagal na siguro?
    Nov 2003
    pinapalitan din yun kasi sometimes the tensioner goes which means better na isabay nalang sila
    usually nga matagal bago mangyari ito.
    Yup mas matagal nga ang timing chains sa timing belts, pero ang mas matibay kung timing gears. Pag binababa lang ang makina tsaka lang pinapalitan itong gears.
    magkano naman tong timing gears? and applicable ba yan to any car?
    Timing gear type is only one type of design sa engine. Meron belt, chain at gear ewan ko kung meron oa iba. usually mga us cars lalo na yung mga luma gaya ng ford taurus. made of special plastic coated ang gears nito para di maingay. vespel ata ang material.
    mantoy::: Dipende sa engine design, some were made to run with timing gears only. While others were meant to be used for timing belts only.
    Dec 2003
    yup 80nga nakalagay sa civic manual....
kailan dapat magpalit ng timing belt....
