Results 1 to 9 of 9
- Jun 2013
- 120
August 26th, 2013 09:45 AM #1I have a 2013 CRV version and my car started making a high pitched woo-woo-woo sound on a cold start, upon accelerating a little bit (placing the tranny to drive and barely or not stepping accelerate). It's usually gone after driving for 15mins. This started after I drove under strong rain and wet road with some puddles, but not flooded. What could be the cause?
Sent from my iPad using Tapatalk - now Free
August 26th, 2013 10:21 AM #2
What you are hearing is probably one of the belts slipping.
Most likely the pulleys are affected. Aircon, tensioner, engine pulley.
Try this for troubleshooting. With a cold engine, start the engine, spray some water onto one of the belts and see if the noise dissipates temporarily.Last edited by number001; August 26th, 2013 at 10:24 AM.
August 26th, 2013 10:34 AM #3
fanbelt araa, like the tensioner, lever arm tensioner shock or bearing's--- of your alternator, compressor.
it could also be your brake or brake disc..
rust accumulated overnight on your brake disc...
- Jun 2013
- 120
- Jun 2013
- 120
August 26th, 2013 03:16 PM #6
August 26th, 2013 04:50 PM #7
Nasa isip ko lang kasi baka kulang na lubrication kaya paguminit na, nawawala. I might be wrong din.
- Jun 2013
- 120
August 26th, 2013 05:03 PM #8
August 26th, 2013 05:56 PM #9
It's best to let it be checked sa casa since under warranty pa yung oto.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
