Results 1 to 6 of 6
June 29th, 2004 10:40 AM #1
at speed no. 2 and 3, sumusobra ang paling ng wiper ko sa driver's side! lampas pa sa windshield, mga 2inches way off!
pinaglaruan ko yung clearance to find the perfect position of both arms, kanya lang di ko talaga makuha, kung ok yung isang arm, yung isa naman ang hindi - di ko talaga makuha, so give up nako - then punta ako sa servitek west ave - ang sabi ng mechaniko sobrang laki na daw ang "play" ng wiper arms ko - ang cause daw is yung mga bushings ng motor ng wiper, baka sobrang worn out na daw, maluwag na. ang remedyo lang daw talaga e palitan yung mga bushings, not even a shorter blade assembly would do the trick "daw", talagang palit daw bushings!
tama ba to? share naman!
June 29th, 2004 01:00 PM #3
yup, that is correct. mura lang naman palit ng wiper bushings. plastic yan eh, so may wear and tear talaga.
June 29th, 2004 03:15 PM #4
Normally, magkanu kaya ang range ng damage? - sabi kasi sa servitek, matagal daw magpalit nito, saka ala pa daw silang experience doing it kaya di sila nagbigay ng formal quote!
June 29th, 2004 08:56 PM #5
Wiper busings used to cost 150-250 8 years ago, hehehe. Ganun na pala katagal akong nagpalit dati. :D
Madali lang palitan ang wiper bushing, malamang sa di nila kabisado kung pano baklasin kaya po sinabing matagal? Banawe boys do it in less than an hour.
July 1st, 2004 10:16 AM #6
when i replaced the wiper bushings of my singkit around 8 years ago, i paid for 100 pesos each. and yes, fafa ungas is correct. madali lang palitan yan. yung tumira ng sa akin, took around 30 minutes.
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
