Last night kasi I was just cruising in the Coastal Rd. with my audio's volume set at 28. Suddenly the volume drops and naging slightly garbled ung audio. I set the volume lower and tried to increase it again, ganun pa rin. So I decided to lower the volume muna. Then after a minute or so binalik ko uli to 28. Umayos na, then maya-maya ganun na naman. Ba't po kaya?
Ride is the one at my sig with a newly installed kenwood kdc-mp4026v HU.
Sir hindi naman po nagdim... faulty volume switch di ko lang sure pero napansin ko po eh parang lumubog ung headunit at ung pocket na nilagay nung binili ko.
Sir pang 2-din kasi talaga ung lalagyan ng HU ko. Since 1-din lang ung nabili ko, nilagyan na lang nila ng pocket ung remaining space sa HU para matakpan.
Opo detachable ung face ng HU. Tinanggal kabit ko po mukhang ayos naman. Pacheck ko po siguro ung connections sa likod sa gumawa.
Up.... after all the reinstallations and all, even re-brackets of the HU, ganun pa rin. After some drives na notice ko na nangyayari lang sya when volume is set * higher than 20 and pag sabay-sabay na ung mids, bass, and high, sa part ng song, dun nagiging garbled and hihina ung volume. Posible kayang kulang sa power sa battery? Di kaya ng speakers? Or kelangan ng AMP? :-/
Thanks sir caloy.. Pero ito wala naman sa kahit mag-break or mag-idle. Talagang pag nag-maintain ka ng volume at more than 20 for about half an hour mangyayari talaga un. Then ngaun ginagawa ko eh papatayin ko saglit sabay after a minute or so on ko na naman. Pag di mo pa rin binabaan ung volume after 5 minutes iiral na naman. Can't really isolate the problem dito... Kalito... =S
Am not sure pero nakita kong iniba ng nag-install ung connector sa HU papunta sa speakers eh? Nilagyan lang din ng mas makapal na wires. Posible kayang yun na yun??? :-/
Just an update... found out the problem the hard way.. In need of replacement na pala battery ko (just natural wear and tear). Luckily tinirik ako tabi na ng gate ng bahay namin. Pagkareplace oks na. :D
