Results 1 to 9 of 9
    Guys, ano kaya yung mga causes ng whistling sound after mapahinga yung makina, naririnig ko to usually sa mga first 5 mins na pinaandar ko yung makina.
    my bet it would probably come from the belts...
    does it mean that it is time for replacement?
    May 2007
    Quote Originally Posted by jusipus View Post
    Whistle type sounds are usually made by intake leaks. Check in the intake manifold area under the hood when the temps outside are right for making the noise. It could be anything from loose bolts to a broken gasket or a faulty hose or sealing cap. Spraying some carb cleaner solvent on the suspected areas to help pinpoint the source of the sound. Remember to torque the bolts to manufacturer's specs when everything is cold under the hood.
    Hope this will help you.
    Feb 2006
    +1 sa vaccum leaks.
    more questions than answers.
    http://tsikot.yehey.com/forums/showt...hlight=whistle
    your question is very similar to mine.
    imo, it doesn't ALWAYS mean bad. since I hear this on mint cars too... I even hear this on tv's and movies.
    Imo, if it aint belt, it's vacuum leaks. try starting the engine on cold while air filter is removed. see if mas loud ang whistle.
    Nov 2003
    idler bearing probably. better to have it checked.
    what's this idler bearing? san sya makikita?
    Nov 2003
    same side as the belts. inside the pulleys.
    depende rin sa kotse tho...
Whistling sound during startup
