Results 1 to 3 of 3
    Oct 2004
    Most would probably say na problema kung may bubbles na nakikita dun sa radiator. But then again meron ako nabasa bubbles not greater than 5mm are normal.
    So naguguluhan ako... ano ba talaga koya?
    Sep 2004
    Where were the bubbles seen, kung sa overflow tank and continuous, baka combustion gases caused by a leaky headgasket.
    If your coolant is not properly bled, you could also see bubbles coming out during the early period.
    Pls. tell us more detail for a more accurate evaluation of your problem/s.
    Oct 2004
    Quote Originally Posted by vicvic
    Nah... nothing specific... its a generalized question kasi... nangungulit lang... so what you mean - any bubbles i.e. sa overflow tank o kaya dun sa may radiator cap would be signs of problems? Ang kulit kc pati sizes ng bubbles meron pa ibig sabihin.
What's the real deal with bubbles?
