Results 1 to 9 of 9
December 11th, 2007 03:38 AM #1
I have a honda civic vti (1998) and here are the following things I want to fix. Please advice me on the price. Baka kasi tubong lugaw gawin sakin sa banawe e.
Right Side Mirror: whole assembly (ninakaw kasi. di ko na magamit yung power feature. may side mirror naman atm)
Coil Springs: Front Stock Springs (nakababa kasi yung harap nung kinuha ko sya)
Power Windows: The mechanism works pero hirap na talaga umakyat baba e.
yun lang po sana may mabait na mag advice. TIA
- May 2004
- 903
December 11th, 2007 10:09 AM #3sa banawe basta lagi ka pupunta dun sa may Shop... Kung pang Honda na Surplus Either Nankai or kanzai meron sila para dyan... Tawad ka lang... Yung Power window kailangan lang ng WD40 yan... Side mirror baka mahirapan ka... Kasi usually japan yang mga yan kaya iba ang Angle sa pasenger side... Coil spring Dami dun.... Basta wag ka makikipag deal sa mga Pumapara... Deretcho ka sa Mga shop at dun mag tanong... Although kahit sa shop may mga oportunista din dyan..
- Dec 2007
- 16
December 11th, 2007 11:39 AM #4Yung side mirror 1500 to 1600 makakkuha k s banawe... Yung power window kung gumagana p yung mechanism try mo lng lagyan ng tire black yung mga gilid n goma subok n yon...
December 11th, 2007 12:23 PM #5
for your power window, try mo bumili sa true valus makati ng silicon spray, maraming brand but ang pinakamura cyclo , spray mo sa channel or rail ng window, wag ka gagamit ng ordinary oil or wd40 masisira ang rubber.
paghindi parin nagwork try mo tangalin ang motor, remove side cover, 3 bolt lang ang motor,and then try mo kung gumagana pa kailangan mong ikabit uli yung connector para sa power window swicth nanasa side cover.
December 11th, 2007 12:51 PM #6
December 11th, 2007 02:23 PM #8
any tried tire black kung ok lang sa window?gumagana pa naman mechanism..mabagal lang tumaas ung window
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
