Results 1 to 4 of 4
Tsikot Member Rank 3
- Oct 2003
- 734
November 6th, 2007 11:27 AM #1HELLO help lng pag troubleshoot!
I need ideas on what could be the problem. after ko ksi magpaint ng engine cover ko syempre remove HT wires etc. and a few kalikot sa vacuum lines sa likod ng oto(carb po engine ko) also adjustment sa clutch hinigpitan ko ksi parang sumasayad or tumutunog pag clinutch ok na swabe na uli pagclutch.
pag on ko and andar ko parang mabigat yun apak ko sa accelerator hindi naman ganun before ako magpaint at magkalikot ksi. tapos pag accelerate na ako limited na acceleration ayaw bumilis o humatak maige hangang 80 nga lng ata eh. napansin ko dati kapag may sinarahan kang vacuum line ganun sa likod ganun effect sa engine eh. chineck ko naman ok naman lahat at naisauli ko lahat ng ginalaw ko. may na miss ba ako icheck o isauli?
ok naman sparkplug ko bago tpos yun HT wire ko is NGK replacement lng 1 yr old. maganda naman idling ko stable at silent yun makina.
what else should i check? thx
November 6th, 2007 12:37 PM #2
First please mention the car specifics like year, model, make, etc so people can help you better.
Second, check that the carpet is not preventing the pedal from attaining its full range of motion.
Third, check and double check each area you went through in the engine bay and see if you got anything jammed, stuck, etc.
Fourth, are you sure sa clutch yung nahigpitan mo and not the accelerator itself?
- Oct 2003
- 734
November 6th, 2007 01:28 PM #3it is a mitsubishi 4G93 carb.
sure na sure! hindi yun accelerator hinigpitan ko! mukha nga pareho eh hehe
bzta ganun ang kupad nya at ang bigat apakan parang kulang sa hangin. pero kahit wlang air filter ganun din eh.
thnx
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 6th, 2007 07:23 PM #4double check mo kung tama ang kabit ng HT wires. Pag mali kasi magloloko ang firing order. Kung baga ang spark plug ay magbibigay ng kuryente sa piston na hindi nakacompress.
check mo rin timing.
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
