Results 1 to 10 of 29
- 152
May 29th, 2003 03:16 PM #1Whats the best thing to do pag nabaha o dumaan sa baha ang kotse mo? Mga knee deep water siguro pero maikli lang naman (5 meters siguro). Is it better to turn off the engine at itulak (example kung may mga boy na magtutulak) or mas okay na naka-on yung engine pero sobrang bagal lang ang takbo? Hanggang 1st gear lang? Io-off ba ang aircon?
Ano ano ang kailangan I-check sa makina? Ano ang pwedeng masira at ipagawa?
Pag nakaahon na sa tubig ano kailangan gawin? I –rev and I-test ang brakes?
Kung nakapasok ang tubig sa loob ng kotse, saan pwede magpalinis? Pwede bang I shampoo ang flooring? Babaho kase pag hindi natuyo. Pano nakapasok ang tubig sa loob?
HELP!
Kung may iba pa kayong safety precautions before and after crossing a knee deep flood, post nyo na dito. Thanks!
- Jan 1970
- 114
May 29th, 2003 03:29 PM #2If you don't have to cross it, then just avoid it altogether.
Otherwise:
1) Turn off the A/C
2) Overrev the engine and ride the clutch throughout the flooded portion
3) Pump the brakes every so often and brake farther from your usual braking distance. The brakes are weaker when wet or submersed.
4) Kung may magtutulak eh patayin nalang at ipatulak
After clearing the flooded portion
1) check sections of the intake for any water
2) check the distributor if its contaminated
3) pump the brakes again just to be sure that you have your brakes back to normal
Detailing shops can remove your carpet and clean it off the car. This is the best way to do it rather than cleaning and drying it from the inside.
May 29th, 2003 03:29 PM #3
depende kung gano kahaba and kalalim yung lulusungin mo. in your case, 5 meters nga lang pero hanggang tuhod naman, which means, entire wheel mo lubog. in your given case too, mas maganda nang pababain yung tubig muna o if you can't help it, patayin mo na lang yung engine at itulak.
kung medyo mababa naman yung tubig, let's say kalahati ng gulong. should go through the water slowly, on first gear and on high rev. dapat patay aircon.
sa makina, kung mababaw lang naman tubig, alang dapat ipa check. kung naka matik ka, you need to change your AT fluid. kung kaya pa, ipa change oil mo na rin.
pag-ahon mo in both cases (ke mababaw o malalim), mawawalan ka talaga ng brakes. drive slowly habang inaapakapakan yung brakes, in this way matuyo yung loob ng brake mechanism. pag umaraw-araw na, pwede mo na ring ipalinis yung brakes. pero pwede mong i-reschedule ito kung alam mong tagulan pa. pagdating na lang ng christmas mo ipalinis.
hope this helps.
May 29th, 2003 03:33 PM #4
Paalala lang po, don't park the vehicle with hand brakes after water fording. Maninikit ito overnight and you will have a hard time disengaging it the next morning. Better leave the vehile parked in gear overnight.
May 29th, 2003 03:46 PM #5
Originally Posted by Ungas
also have your drum brakes cleaned.
May 29th, 2003 04:24 PM #6
tama kayo about the handbrake after going through floods
as for teh change tranny fluid.. on most jap cars... you'd definitely have to do that.. kasi ang baba ng dipstick ng A/T and even if its a sealed tranny... papasukin yan sa dipstick.. unlike MBs.. ang dipstick nya is located as high as the engine itself.
for matic, put it in D, foot on the gas pedal (a little higher than usual rev).. other foot on brakes.. just in case na sumibat...
May 29th, 2003 04:25 PM #7
galing nyo talaga buti na lang nabasa ko yung dont park with handbrakes... pag galing sa baha..
he.he.he... paano kung galing sa carwash... no handbrakes din ba.?
May 29th, 2003 04:29 PM #8
Bakit sa off-roading 101, halos murahin tayo ng instructor kapag tinapakan natin ang clutch while submerged?
For me, no clutch underwater ang policy ko (unless kelangang huminto, quick step lang ginagawa ko then slam into neutral).
Although unnerving at first, a well-maintained engine will actually idle underwater.
May 29th, 2003 04:49 PM #9
Originally Posted by marwen
Initial gear shifting apak clutch then bitaw sa 1st gear, when the vehicle is about to stop, I just pull it to neutral without stepping on the clutch. Ginagawa ko lang ito pag malalim at abot flooring ang baha. Kung lampas rims lang ang babaw ng tubig drive it like usual pace.
- 152
May 29th, 2003 05:05 PM #10salamat sa reply. helpful itong thread na to kse rainy season na e di naman maiiwasan minsan na may madaanan tayo na baha.
di ko alam yung tungkol sa handbrakes...
is there a hole sa ilalim ng car na kailangan may cover? iniisip ko kung pano nakapasok yung tubig e... at tanging sa likod lang ang nabasa. sa likod ng driver.
magkano yung palinis ng flooring?
I just bought an OEM Honda washer fluid. Ok Lang kaya ihalo sa naka mix na filtered + distilled ...
Windshield Washer Fluids Talk
