Results 1 to 6 of 6
  1. #1
    ano kaya problem ng akin? yung front ng car ko, mas mataas ang distance ng fender sa gulong, unlike sa likod na medyo mababa. 2 fingers ang height sa likod, while sa harap, halos 5 fingers! iba yung shocks nya sa front and rear, sa harap galing sa rapide, sa likod KYB....is this the reasoN or iba pa?
    Feb 2004
    can't really tell why but it could be the shocks as you suspect. but keep in mind that the front wheel opening is always bigger than the ones in the rear. it's normal to have more clearance in the front than in the back but ,in my opinion, not sa much as what you have right now. what other work was done to your suspension?
    Oct 2003
    phillipogi, baka s spring ang problema..... it can be the shocks at the back, i hope this can help or ang maipapayo ko sayo bring it to SPEEDYFIX ok ung shop nyas may shaw besides toyota.....
    Dec 2002
    did you just have the front shocks replaced? malamang bago yung shocks mo sa harap kaya mas mataas ang tingin mo kaysa dati.
    problem ko yan ngayon..new shocks sa harap kaya reverse tukod racing ako ngayon..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Nov 2003
    reverse tukod racing...
    hehe! ayus ito... bagong uso
    we can install lifters sa lowed side para pumantay pero taka lang ako baka magmukhang off road yung auto mo. di kaya mali yung shocks na nakakabit?
mas mataas ang harap kaysa likod - help!
