Results 1 to 10 of 15
Threaded View
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 2nd, 2004 10:45 AM #11hmmm... i initially thought it would be a busted radiator also pero since napaayos mo na then try the waterpump next. replacement brands like gmb are ok and i've had good luck with them
if the compression test results are ok and even then this means the gasket is ok.
actually, if the car isn't overheating then you have no problem naman
