Results 1 to 10 of 11
April 27th, 2004 09:36 AM #1
ano usually ang mga telltale signs na kailangan mo ng magpa camber? medyo hindi na kasi normal nararamdaman ko sa oto ko eh. parang medyo magulo na yung manibela in high-speeds, tapos ang lakas na ng huni ng gulong sa harapan, although i know one of the factors here is yung NCT3 na tires ko. yung tire wear naman is still even.
April 27th, 2004 03:49 PM #2
1. Kung may nararamdaman kang kabig ng manibela.
2. Kung di na pantay ang upod ng goma.
3. Kung nararamdaman mong nauuna ng bahaygya ang kabilang gulo.
4. Kung napapadalas ka sa malalim na lubak, kelangan check ito taon-taon.
April 28th, 2004 07:47 PM #4
Guys what if i just had my alignment and camber late last year. Pati paglipat ng goma. Then lately sa NLEX magalwa uli manibela and may kabig sa kanan. Alignment and camber uli kaya?
April 28th, 2004 08:11 PM #5
Anually naman dapat ang check ng front end alignment. Nagtitipid na lang kasi tayo kaya kung kailan may maramdaman tsaka lang pasisilip kung anong diperensya. And to add, one year of tire usage should create enough tread wear for you to rotate them.
Normal naman na kumabig ang sasakyan sa kanan lalo na may kalumaan na ang sasakyan. All our roads are made to slant on the right for water spillways. Subukan nyo po sa gitna ng two way concrete road para pantay at tignan kung may kabig pa rin.
April 29th, 2004 04:16 AM #6
mga sir... medyo related yata yung problema ng crv ko... kapag nagha-half brake ako, medyo nanginginig yung steering wheel ko. But kung full breaking naman hindi naman nanginginig.
April 29th, 2004 08:01 AM #7
Thanks sir! I'll try that. But what if kumakabig pa din then i'll go have it checked na siguro. Hirap kasi sa NLEX konting bitaw kabig agad.
April 29th, 2004 01:34 PM #8
Tikoyman::: I belive you are experiencing brake shudder. Uneven wear on brake pads at rear drums will be my primary doubt. Subukan nyo po munang lihain para pumantay ang itaas at ibabang part ng pads. Nangyayari ito kadalasan sa mga rear drums na may emergency park brakes. Upper part lang ang gumagana at sumasayad sa drums kaya hindi pantay ang upod. Isabay nyo na rin ang pag linis ng front disc pads, hangin at liha lang ang katapat para pantayin ulit. May mga alikabok, buhagin at iba pang duming sumisingit kaya hindi pantay ang upod.
zanch::: Subukan nyo po muna ng tire rotation. Either 5 wheel or 4 wheel tire roation might do the trick. Less than 1thou lang naman ang alignment so it won't hurt much on your pocket too.
May 1st, 2004 09:58 PM #10Originally posted by zanch
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
