Results 1 to 7 of 7
    Sep 2005
    Two months ago, there was a leak of brake fluid between the master cylinder and the vacuum booster (hydrovac as what the mechanic calls it) so it was fixed by means of a repair kit. Ngayon, ito at bumalik na naman. Ano kaya ang mas dapat ba na gagawin? Any advice would be much appreciated.
    Aug 2003
    wag na repair kit. palitan na yun part ng original.
    tanggal agad sakit ng ulo mo.
    Nov 2003
    replace the assembly all the time. repair kits hardly last.
    Apr 2005
    what if walang makitang leak pero lumulubog brakes?
    Feb 2006
    try bleeding. baka me hangin
    Nov 2003
    yup, bleed muna and if does not work then malamang internal leak sa brake master.
    Jan 2008
    +1 po ako sa replacement ng assembly. twice ako bumili ng repair kit kasi baka daw di maganda ung una pero ganun pa rin. sayang lang pera sa repair kit. ganun din sa clutch master, dapat buo na.
Leak from Master break cylinder
