Results 1 to 6 of 6
- Oct 2006
- 32
November 3rd, 2007 09:10 PM #1mga mates, may tanong lang po sna ko sa mga expert diyan, san po ba ang first cylinder ng 4g15 na engine 12valve, pag naka TDC ba? alin po ba ang iadjust yung ist cylinder ba o yung running mate nya..tia po mga master
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 3rd, 2007 10:08 PM #2I'm no expert, siraniko lang.
You adjust valves pag naka TDC. Start with No 1. Its the one nearest to the flywheel. After adjusting no 1, rotate the flywheel so no 2 is in TDC position. Adjust no 2 and so on until you finish with the last one.
I know there are shortcuts but its beyond what I know.
Pls correct if I said something wrong.
- Jun 2006
- 2,605
November 4th, 2007 02:41 PM #3Wanted to edit but wala na yung edit button. May time limit ba for editing?
Instead of doing 1,2,3,4 you should do 1,3,4,2. Thats the firing order of most 4 cylinder engines and it should be faster for you.
- Oct 2006
- 32
November 4th, 2007 05:56 PM #4thanks mate, so pag nakaTDC yung iadjust na una, e yung malapit sa timing belt?
- Jun 2006
- 2,605
- Oct 2006
- 32
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
