Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    I just want to share the memo I got from our fleet management:
    Below is a portion of the official statement of Nissan on the use of
    synthetic oil on Nissan cars.
    " ... it has been their policy that use of synthethic oil is not
    > recommended for Nissan vehicles. The reason for which is some synthetic
    > oil have higher acidity compared with conventional mineral based oil
    which
    > tends to wear out the engine gaskets and oil seals causing oil leak.
    > Engine related problems caused by the use of synthetic oil will void the
    > warranty."
    what kind of nissan car in particular?
    we have a '99 nissan cefiro and fully synthetic oil has been used for that car ever since it was brand new. it still runs as good as new.
    Dec 2003
    does that apply to honda or bmw? may negative effects pla full synthetic??
    Sa Safari na bago may ganun na sticker sa hood/engine cover.
    What particular synth oil would that be in question? Is it applicable to older or newer engines? :?
    I have a friend whos been using synth on their Nissan Sentra for quite sometime (5 years?) and they still have no engine leaks. However, i know of a Cfeiro thats been using synth and it encountered leaks. The SA told me the same thing before when i wanted to put Synth in my Frontier... honestly, i wanted to whack the oil on his head because it was the first time that i've encountered such back then... :D I was told by other SA's that if you use synth, chagne pa rin every 5K.
    Jan 2003
    All nissan cars? I haven't noticed any problem on my Terrano. Been using full synthetic oils since my wife & I bought it. Kindly specify which Nissan models mustn't use synthethic oils.
    sa patrol, there is a warning sticker not to use syntheric oil beside the engine oil filler.
    Signature
    our fleet cars are Nissan sentra FE
    Jun 2004
    no matter what oil u use. u should change the oil regularly. especially for diesel engines. sludge buildup is the worse thing you want in your engine. if you seldom use you vehicle (sunday car) and would not change oil with in 6 months then go synthetic. i was told that regular or premium oil has an expiration of 6months after first use.
    Jan 1970
    i believe NMPI tend to play safe. cant blame them.
    but voiding its warranty is simply cruel:dead:
Use of Synthetic Oil on Nissan Cars
