Results 1 to 10 of 12
March 6th, 2007 04:59 AM #1
Tsikoteers,
Question.. I had my rack end, tie-rod replaced. nun pina-align and camber ko 0 nman lhat. on the dot pero nag swerve sia sa kaliwa..
I was told na baka nde pantay ung putol ng springs ko and tabingi sia kaya ganun..
Is there a possibility na ganun nga?
Appreciate your response.
March 6th, 2007 05:21 AM #2
March 6th, 2007 06:31 AM #3
Dude, ilang beses ko na pinabalik-balik since it is still under the warranty. Pero ganun talaga eh..
Is it possible sa shocks din kaya or springs?
March 6th, 2007 11:28 AM #4
na check mo ba sa print-out sir kung tama sa specs ang pagka align? or bka gulong na me problema, swap mo muna gulong then check uli
March 7th, 2007 12:41 AM #6
na-try ko na din ipagpalit ung 2 tires sa harap pero ganun pa din. I was thinking nga din na baka sa gulong but to my dismay wala din nangyari.
No print-outs sir. It's not one of those servitek shops. Medyo mhal din kasi and ung shop na pinuntahan ko laser nman gamit nila.
But still ganun pa din.
Have you thought of anything that may cause this?
March 7th, 2007 01:01 AM #7
try rotating your tires baka sa gulong lang...
i'm not a big fan of wheel alignment shops. especially those who will recommend camber correction out of the blue (siyempre its the most expensive service) when you're only asking for toe correction. experience ko dati when i was new around cars. i went for a wheel alignment because i just replaced steering boots. and medyo may kabig din sya, i asked for alignment, di ko alam na may camber alinment din pala, akala ko wheel toe alignment lang. kung anu anong alignment ginawa sa front tires ko di naman nawala ang kabig. napagastos lang ako.:twak: nung pinagpalit ko yung gulong ko sa harapan, ayun nawala.
March 7th, 2007 01:51 AM #8
March 7th, 2007 11:27 AM #9
mas maganda sir yung may print-out machecheck mo yung actual vs sa specs makikita mo dun kung hidi hula lang alignment
March 8th, 2007 12:55 AM #10
hmm.. i tried switching the tires ng back to the front pero ganun pa din. I tried switching all the tires pero ganun din eh. may kabig pa din.
Siguro I need to have all of my wheels check kung oblong sila..
Pero kung oblong ung isa eh di dpat lumipat ung kabig...
I was still thinking about the coil springs eh..
Baka nga nde kasi pantay ung putol ng springs nung dating may ari.
hmm... pero dpat nde pantay ung tau ng auto ko.. hmm..
what u guys think?
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
