Results 1 to 10 of 10
- May 2007
- 401
July 3rd, 2007 08:43 AM #1Pano malalaman kung kelangan mo ng ipa-tune up ang isang sasakyan?
Thanks.
July 3rd, 2007 09:02 AM #2
Follow your PMS schedule in your car's manual. Otherwise, have your car checked after every 5T km or 3 mos., whichever comes first.
If you drive your car everyday, you'll "feel" it if its not being responsive or efficient as it was when you first acquired it.
Tsikot Member Rank 5
- Nov 2003
- 3,848
July 3rd, 2007 10:42 PM #3you should do it regularly.
on efi engines though 5k kms is too soon. tsaka palit plugs lang naman yun so every 10k kms is ok with regular plugs. air filter halos ganun din. fuel filter every 30-40k kms. tappets every 40k kms.
August 13th, 2007 08:16 PM #4
one basic question lang po: what checks/adjustments/corrections/replacements are made during tune-up (at the very least)?
August 14th, 2007 02:26 AM #5
- Nov 2003
- 3,848
August 15th, 2007 08:26 AM #7tappet adjustement for 4cyl gas engines is 500.
normally you just check the timing pero aside from replacing the plugs then no other major work is needed.
August 15th, 2007 11:28 AM #8
thanks sir speedyfix... follow up questions lang po: how about things like valve clearance adjustments?
- Nov 2003
- 3,848
August 19th, 2007 04:02 PM #9adjusting the clearance should be done every 30-40k kms. sabay na yun with the fuel filter.
What was the starting pressure?
Need recommendations on tire inflator.
