Results 1 to 7 of 7
June 7th, 2006 12:32 PM #1
Mga gurus, ask ko lang kung ano sulutions nyo pag mahirap isara yung sa trunk. EG Sedan yung sakin. Simula nung nabili ko sya last year eh hirap nyang isara, as in kailangan bubuwelo ka ng malakas para masara sya. Pansin ko lang yung shocks nya on both sides parang di na gumagana as in pag open ko either using key or yung switch sa driver side dapat aangat sya ng ilang inches. Yung shocks kaya culprit? If yes, magkano po kaya yun? Sama nyo na rin pati labor.
tia
June 9th, 2006 07:35 PM #3
ganyan din eg ko dati...di na gumagana yung shocks pag angat pero mabilis naman sya maisara.
baka yung lock nya may diperensya...Last edited by baiskee; June 9th, 2006 at 07:43 PM.
June 10th, 2006 12:12 AM #4
or a misaligned trunk from a collision. eto quick fix. try adjusting the latch kung san naghu-hook yung trunk. be aware lang na baka hindi umayos yung pag seal ng trunk ha.
June 10th, 2006 11:31 PM #6
para madali makita ang adjustment na kailangan sa latch maglagay ka ng tao sa loob w/ flashlight then isara dahandahan para makita niya ang adjustment na kailangan, wag mo lang kakalimutan ang susi baka maibigay mo sa kanya at hindi mo mabuksan.
June 12th, 2006 09:22 AM #7
Thanks po sa mga advises nyo. try ko po i-adjust yung latch mamayang hapon...hope may time ako. keep on comming. =)
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
