Results 1 to 10 of 16
March 5th, 2005 10:58 PM #1
guys, what do you use as your windshield wiper fluid? plain water, liquid soap solution, commercially available windshield wiper formula or something else?
and where to buy it too...thanks!
March 5th, 2005 11:09 PM #2
i put a self-mixed solution of distilled water and car shampoo (just a very small amount)
March 5th, 2005 11:13 PM #3
I just use Tap water, you can use distilled water / wiper washer solution available at Hans, True Value, Ace Hardware outlets
March 5th, 2005 11:16 PM #4
add alcohol too (isopropyl) to make the fluid evaporate faster after you spray it on the glass.
March 5th, 2005 11:23 PM #6
probably it would especially kung taga cavite or rizal province ka hard water yung nandon e.
March 6th, 2005 12:43 AM #8
I use filtered water from our own faucets, to avoid clogging and I mix it with windshield wiper fluid.
March 6th, 2005 09:58 AM #9
ako kasi i use ordinary water lang. at first ok naman, pero the longer you drive, yung mga tumatalsik sa windshield mo (like road oils, grime and stuff) di na kaya tanggalin ng tubig..so papangit na yung visibility mo.
any brands of windshield wiper formula recommended?
March 6th, 2005 10:45 AM #10
i mix water with a small amount of car shampoo as well...works for me...considering i also apply rainx to my windshield, mejo magalas na pagtagal tagal...brings back smoothness naren at the same time.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
