I'm not trying to be a cheapskate . . . just being practical.
Any idea?![]()
Remove loose dirt/dust. Soak/wash with diluted joy liquid detergent and dry. Apply small amount of singer oil.
Sent from my Nokia5110i-VgT using Tsikot Forums
No sir.
Engine oil is a lot viscous, 97 vs 9.6 *40degC. This means pwede magform na gum ang dust sa filter if you do.
The practical move is to use k&n recharger kit. Subok na yan e. Using detergent and other oils can damage your filter or engine.
How do you apply singer oil? Spray it directly to the filter?
Posted via Ay****
kapag oily at sobrang dumi, I sprayed it w/ degreaser then soak/wash it with dishwashing liquid. after washing, I bring it to my neighbors vulcanizing shop and blow dry it with compressor air. kapag sinisipag ako, nilalagyan ko ng recharging oil ;) lately hindi na, I run it dry as it is na lang and ok naman. btw, make sure to clean your MAF sensor too, it makes a lot of difference kapag nalinisan yung MAF sensor.
I use engine degreaser also to clean it then use water & dishwashing liquid for final cleaning. Air dry lang ako na mga 1 day tapos I use 2t oil.
Apply ko lang 2t oil sa topmost part nung filter tapos i let it drip down. After a day okay na yan. First time ko sobrang dami nga 2t na nagamit ko, dapat kunti lang pala, mga 50ml would do. 2 days yan kay may reserve ako na air filter. Every 15,000kms ako naglilinis.
apektado at less effective ang filtering niya kapag dry, sa oil kasi kakapit dapat yung dumi. pero mas madali naman huminga makina mo kapag dry. when applying oil, just be careful lang not to put too much oil. nung bagong bili mo yung K&N mo napansin mo naman siguro gaano siya ka-oily ;) kapag sobra lagay mo ng oil, malamang kakapit sa MAF sensor probe mo yung oil at dumi, hindi masyado madetect nung sensor yung air flow so mahina hatak.
unscrew mo lang yung sensor, then spray mo ng electronic contact cleaner yung sensor probe. kapag natuyo ikabit mo na. ramdam mo malakas ang hatak. you can clean it same time sa filter, kung madumi na yung filter malamang madumi din yung sensor probe.
Thanks for your inputs fellow Tsikoteers. Pero may hirit pa ako:
My friend suggested water+Joy dishwashing+rubbing alcohol as cleaner & WD40 as oil. What do you think of these replacements?
Noob question guys;
Where is the MAF sensor located? un ba ung malapit sa filter box? TIA
Any suggestion where i can buy cheaper knn filter for my civic fd?
Posted via Tsikot Mobile App
