Results 1 to 10 of 11
- Jun 2004
- 207
September 10th, 2008 04:54 AM #1Saan makakabili nito, yung mid-range brand lang? Ito yung pang-torque sa lugs ng wheels.
September 10th, 2008 08:39 AM #2
sa suking auto supply meron normally beam type ang available.
btw ilang newton metre (N m) or pounds-feet (lb-ft) ang required sa wheel nut mo? afaik the tighter the better. i only use torque wrench if the tightness of screws and nut is crucial.
- Jun 2004
- 207
September 13th, 2008 06:09 AM #4
ako din alam ko torque wrench sa citical parts lang like rocker arm bolts...
anyway, sir biggs is that constant Nm for all wheels?
- Jun 2004
- 207
- Nov 2008
- 44
January 21st, 2009 09:33 AM #6ako lagi meron dalang torque wrench para sa gulong kapag na flat...mas maganda kasi kung perfect yung higpit ng nut...eh meron kasi kaming torque wrench...kaya gamit ko...
- Sep 2008
- 102
October 1st, 2009 09:57 AM #7i-up ko lang sana to. meron ba sa inyo nakakaalam san nakakabili ng nut at magkano ito? nawawala kasi ung isang nut ng gulong ko e. thanks in advance ;)
- Jul 2003
- 573
October 4th, 2009 06:10 PM #8you can find nuts at auto supply. some have surplus nuts available by the piece, so you don't have to buy a complete set. just bring a sample or bring your car for fitment.
October 4th, 2009 08:59 PM #9
biggs,
please don't give the wrong information. not all vehicles have the same torque settings on the lug nuts. the deciding factors by the engineers are:
a. stud bolt threaded diameter
b. thread pitch (measurement of thread crest intervals in mm. or threads
per inch)
c. the strength grade of the stud bolt or the lug nut
d. the number of lug nuts on the hub
e. designed axle load
to make sure, please refer to the owner's manual or the shop repair manual. and "the tighter is better" maybe dangerous as the stud bolt will stretch beyond its designed tensile strength and when you hit a pothole- voila! you might see a flying wheel
jick
November 12th, 2022 08:53 PM #10
today, at fisher mall, there was a concession selling some tools at the ground floor. they had torque wrenches for sale (brand/accuracy not confirmed) when i opened the storage box and checked the scales, i noticed the thimble was not at the lowest reading on this case 0 Nm. this torque wrench was not stored properly. leaving a click type torque wrench on a setting other than the lowest on the scale makes even the most trusted brand, reputable quality click type torque wrench tired, hence, erroneous and inaccurate. if you plan on buying a torque wrench and don't like to reset it to the lowest setting, buy the beam type or the dial type instead
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
