Results 1 to 5 of 5
- Sep 2003
- 13
September 8th, 2003 10:46 AM #1There's a certain odor inside my car ( smells like grease) during sudden accelerations. I had the exhaust checked and it looks ok naman, no leaks or whatsoever.
what do you think is causing this? will undercoating resolve this?
what about the airconditioning system? do I need to have this checked as well?
My car is a '94 nissan sentra, btw.
thanks.
September 8th, 2003 11:28 AM #2
check mo muna aircon vent mo(the opening that gets air outside)...minsan worn out na yung rubber nito....
September 8th, 2003 11:39 AM #3
Baka may oil leak sa engine compartment which gets burned whenever the engine heats up. Kaya amoy mo yung vapor.
- Sep 2003
- 13
September 8th, 2003 11:58 AM #4thanks for the immediate inputs. more questions....
saan located ung aircon vent?
paano ma-check kung may leak sa enginer comaprtment
September 8th, 2003 12:06 PM #5
A/C sucks air at the grilles at the base of the winshield where the wiper parks.
Check your engine compartment firewall (the partition between engine compartment and passenger compartment). Baka punit or missing na ang ibang rubber plugs/grommets.
VinFast VF 3
